What is this?
Sep 16, 2019 | 08:02 PM
Sep 16, 2019 | 08:04 PM
I believe that is used for a Tow Bar attachment.
Some tow bars would attach to the bumper. No can do on a C3.
Some tow bars would attach to the front frame. No can do.
I bet that hangs way too low for your liking or speedbumps.
Sep 16, 2019 | 09:07 PM
Their removal is on my to do list
Sep 17, 2019 | 09:57 AM
Looks like you may not have to remove the sway bar. Maybe just a few bolts and it will slide down, with any luck.
Sep 17, 2019 | 10:04 AM
OOOO, there is one on each side...that seems redundant. Anything like them on the rear?
Sep 17, 2019 | 01:11 PM
Quote:
Originally Posted by
wer2xu
Actually there are. Was a TSB issued and a recall to add them on later models.
Sep 18, 2019 | 08:34 AM
Cruise-In II Veteran
stingr69
...Was a TSB issued and a recall to add them on later models...
The OP's towing set up is aftermarket.
Sep 18, 2019 | 08:53 AM
pltmgr
There is a cool factor to it
Sep 18, 2019 | 01:39 PM
x2....now go over the bottom of the car and see what FLAT TOWING DID TO IT!
driveline, rear diff fluid, u-joints. etc.
Actually seeing this (I've seen it before) makes me a little queasy in the stomach....
miles on odometer DO NOT really reflect reality.
I've seen where they pull the driveshaft and then tow it across country...over hill and dale....never knowing if the rear end is overheating, leaking etc.
Best of luck an sleuthing.
Unkahal
