belt squeal
Old Nov 12, 2002 | 10:35 PM
vettedreams's Avatar
vettedreams
Default belt squeal
Iwould like to know how to get rid of the squeal. I've replaced all pulleys but the alt. pulley. That could be next.
Old Nov 12, 2002 | 10:39 PM
81Vette_by_eric's Avatar
81Vette_by_eric
Default Re: belt squeal (vettedreams)
have you checked the belt tension?
are they new belts?
Does it squeal all the time or only at higher rpm?
they make a belt grease that you pick up at your local auto store for a couple of bucks. i used some and it helped out.
Old Nov 12, 2002 | 10:59 PM
vettedreams
Default Re: belt squeal (81Vette_by_eric)
Yup, new belt even tried that spray that NAPA sells for squealling belts, the belt has about 1/2" play in it. I may do a better job of the spray again. I can hear the squeal at low r.p.m"s At 55mph I"m turning 3000 or better rpm"s, so the engine is singing loud & proud, cannot here anything else!
Old Nov 13, 2002 | 04:35 AM
virtue4u's Avatar
virtue4u
I found that the belt grease never permanently solves the problem and may be damaging your belts. Go to a big sports store. Go the the baseball section. Buy a stick of batters rosin. Put the rosin on the belts. That will last longer than the belt grease.
[Modified by virtue4u, 3:36 AM 11/13/2002]
Old Nov 13, 2002 | 08:06 AM
Edzred72's Avatar
Edzred72
I had the same squealing problem....untill I installed Gates belts. Smooth as silk now!!! :cheers: :cheers:
Eddie
Old Nov 13, 2002 | 09:31 AM
Alwyn678's Avatar
Alwyn678
Default Re: belt squeal (Silvr77)
Did you remove your original Alternator bracket.....and use a Chrome one?..I did and it would would bend (CHEAP AZZ PEP BOYS PART) when I reved it about 3500k......I bought an original part from the chevy dealer and problem solved :cheers:
Old Nov 13, 2002 | 09:59 AM
vettedreams
Default Re: belt squeal (Alwyn678)
I did replace the bracket but I replaced it with $180 aluminium set-up, it seems to stay put when I rev the BB.
Old Nov 13, 2002 | 10:19 AM
Alwyn678's Avatar
Alwyn678
I guess it could not hurt to put the original back an and find out :confused:
Old Nov 13, 2002 | 03:02 PM
woodenichols's Avatar
woodenichols
I posted this same topic on Sunday but was unable to read any of the replies because of forum problems! :cuss My "68" squeals bad at around 3200 rpm. Tried dressings, new gates belt, alignment and tension. Nothing! :confused: New belt worked for about a day and then right back squealing. It's driving me nuts! :crazy: Any other ideas or suggestions?
Steve
Old Nov 13, 2002 | 05:11 PM
vettedreams
Default Re: belt squeal (woodenichols)
Steve, I feel your pain! I just tightened up the belt again and like you say it just won"t last. I wonder if I need to try a thicker belt?
Old Nov 13, 2002 | 05:23 PM
woodenichols
Someone suggested tome a thinner one. I don't know :confused: ???
Steve
Old Nov 14, 2002 | 01:23 PM
Schwee's Avatar
Schwee
Not just Gates belt, but the Gates "Green Stripe" belt. Top of the line.
To belt squeal
