Soft pedal after bleeding brakes
Old Sep 21, 2019 | 10:49 PM
Ace11's Avatar
Ace11
Navigator
Default Soft pedal after bleeding brakes
Title says it all. Brake pedal is still soft even after bleeding brakes, releasing all air bubbles. Any insight would be greatly appreciated . 74 corvette
Old Sep 22, 2019 | 02:13 AM
cagotzmann's Avatar
cagotzmann
So what was done to the brake system to let air in the brake lines ?. Most common reason for a soft pedal is air in the brake lines.
This could be in the
1. Master Cylinder
2. Caliper pistons area
3. In the caliper it self.
So the next question is what method did you use to bleed. ? And why did you try to bleed the brakes ?
Old Sep 22, 2019 | 04:40 AM
Ace11's Avatar
Ace11
Navigator
I would assume the reasoning air was let into the system in the first place was from a leaking caliper. I replaced the leaking caliper and bled the brakes the 2 man way.
Old Sep 22, 2019 | 05:40 AM
Bikespace's Avatar
Bikespace
Using the two man method should work, but some air can get past the threads of the bleed screw if your timing is off with your partner. There could also be air in the master cylinder if it ran dry at any point.
A Motive pressure bleeder is another option to try. I've also used some thread sealant on the bleed screw threads (NOT the tapered seat).
Old Sep 24, 2019 | 05:05 PM
mardyn's Avatar
mardyn
Subscribing:
Having problems with mine too... have bled and bled and bled but the pedal remains sponegy.
It stops pretty good, but the pedal doesn't feel right.
Right front caliper bleeder never really seems to clear up completely, also rear brake calipers (while free of air) don't
really seem to be moving much fluid.... I'm wondering if old rubber lines might be collapsed internally??
mardyn
Old Sep 24, 2019 | 05:30 PM
TCracingCA's Avatar
TCracingCA
I get a sore leg just thinking about this!
I think I would rather have my Father paddle my behind with the holes cut for velocity, than to help him bleed the brakes!
Old Sep 24, 2019 | 07:00 PM
revitup's Avatar
revitup
Never heard anyone say "my brakes are still spongy" after bleeding with a Motive pressure bleeder. Seems there's too much room for error and much unsatisfactory results with any other method on these cars.
Old Sep 24, 2019 | 09:14 PM
Bikespace's Avatar
Bikespace
And if you can't prove that your brake hoses are less than 10 years old (dated receipts, or you did it yourself and documented it), go ahead and replace them, same as tires.
The one other tip I have is to tap the calipers and junctions with a wrench, to dislodge the last of the air bubbles.
Old Sep 25, 2019 | 09:34 AM
stingr69's Avatar
stingr69
Most of us here have suffered a few times with the C3 brake bleeding issues, It is unique to the C3 as I have never had any trouble on any other car doing it the traditional 2-man way. If someone is posting here, they are new to the C3 but not new to brake jobs. We have hundreds of threads on this common problem.
Motive pressure bleeder was the answer for me and I posted that in the other thread as well.
Old Sep 25, 2019 | 10:53 AM
Gunfighter13's Avatar
Gunfighter13
Most of the time, it's from bad flex hoses or caliper. Make sure all the brake components are in good shape. Replace the flex hose if they are original.
No fancy bleeder is needed. I gravity bleed followed by a bottle bleeder, it works fine.
Old Sep 25, 2019 | 12:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
Spot on!
And most of us know to buy brakefluid in 55 gal drums too.
And yet there are people here that say they've never had an issue and got the chore done perfect the first time. To those lucky people, I say you better count your blessings and buy a lottery ticket.
C3 brake issues are real. If they were not a concern, you would not see two posts a week on here about the stinkin' brakes.
Old Sep 28, 2019 | 06:56 PM
fiatche's Avatar
fiatche
7th Gear
Most reliable method I've found is pretty simple... Gravity. I also have a '74 and after days of fighting them with a pump, 2 man method, etc, finally just put the car on 4 jack stands, opened all the bleeder screws, had plenty of spare brake fluid ready, and let gravity do it's job. Brakes work amazing now, and I'm not sure I'll ever do them any other way again. Just my experience.
Old Sep 29, 2019 | 12:11 AM
davidbii's Avatar
davidbii
lol. That brought back some memories.
Old Sep 29, 2019 | 06:23 PM
kansas123's Avatar
kansas123
Old Sep 29, 2019 | 06:41 PM
Jstan2014's Avatar
Jstan2014
Old Sep 30, 2019 | 01:06 PM
PeteZO6's Avatar
PeteZO6
This Harbor Freight bleeder tool works very well, although it requires you have an air compressor. It utilizes fir flow past an orifice to create a vacuum that pulls the brake fluid out of the caliper. In all the years I've owned my C3, this is the easiest method I've found. Here’s a link Pneumatic Brake Bleeder to the tool.
To Soft pedal after bleeding brakes
