Windows Jam
Old Sep 23, 2019 | 10:43 AM
motogotro's Avatar
motogotro
Default Windows Jam
I've replaced the window regulators and motors on both doors of my 81 and the windows go up and down very nice now but every once in a while they will jam, typically in the up position. When that happens, the only fix is to loosen the 3 bolts that hold the motor on the regulator until I hear a pop and then I can lower the window a bit and tighten the bolts and everything is fine again. Anyone seen this before?
Old Sep 23, 2019 | 05:49 PM
bazza77's Avatar
bazza77
Yes ,I have heard of it happening , but usually with old worn out parts ! In your case assuming your replacements are brand new and have good teeth ,the only thing I can think of (aWAG) is your window is going too high and is running out of teeth on the regulator , not sure its even possible , but that would be a simple fix , just lower the two upper stops a touch and see if it stops binding .
