Power Windows Stopped Working
Old Sep 27, 2019 | 09:25 PM
WiscoVett's Avatar
WiscoVett
2nd Gear
Default Power Windows Stopped Working
Just bought a 1978 Vett TODAY. Everything was working on it until I tried rolling up both windows at the same time. They both immediately quit working and I ended up driving 2 hours home in the rain with both windows half rolled up. Currently have some fans drying out the interior, but while I wait I'd like to get some ideas for what the cause could be and how to check and fix it.
Thank you.
Old Sep 27, 2019 | 11:38 PM
caskiguy's Avatar
caskiguy
First check the fuse. They list one to 77' then skip to 79 so I'm thinking 78' is very similar.
http://repairs.willcoxcorvette.com/1...te-fuse-panel/
Old Sep 29, 2019 | 03:59 PM
SwampeastMike's Avatar
SwampeastMike
Congratulations on your purchase. Welcome to the wonderful world of fixing old Corvettes
Not sure if your windows have a fuse or a circuit breaker. The fuse box is up above the driver's left foot. Like everyone you'll say some choice words about the location and how difficult to access '77 still uses glass cartridge fuses. If the windows have a circuit breaker it looks like a little aluminum covered box. The circuit breakers are supposed to self-reset but they don't always.
Anyhow the fuse should not blow when operating both windows at the same time. Once you get them running see if one (or both) go down significantly faster than they go up. If so, the assist spring is broken and needs to be replaced. It's not a terrible job but in all likelihood you also need to completely disassemble the mechanism(s), clean, relubricate and replace worn rollers, weather seals etc. Work on your second door will go much faster than the first! Don't wait until the motor(s) go out as it's significantly easier when they're working and you can get the glass into the mechanism into the proper position for removal.
Old Sep 29, 2019 | 08:37 PM
riverracer au's Avatar
riverracer au
also check the wiring where it goes thru the door to the frame, the bendy section of hose.
mine had a broken wire in the harness, not an easy fix either.....
Old Sep 29, 2019 | 08:52 PM
WiscoVett's Avatar
WiscoVett
2nd Gear
Wow, that fuse was super fun to change out. So glad they crammed the fuse box way up in there where it's so easy to access.
Replaced the fuse, and the windows are working again, thanks.
Old Sep 30, 2019 | 03:31 PM
SwampeastMike
Glad it was a simple fix. Made a stupid mistake in my previous message--the fuse should not blow when operating both windows at the same time. Don't forget to see if the window(s) go down much faster than they go up! If so the assist spring is broken and it will kill the motor.
To Power Windows Stopped Working
