Need to add Caster...How?
Old Sep 30, 2019 | 10:30 AM
karkrafter's Avatar
karkrafter
Default Need to add Caster...How?
I posted this on the C1-C2 board and thought I'd ask my C3 brothers for their experience on this as well.
I don't have the specs in front of me but if I remember correctly my front guy could only squeeze 2 degrees of caster last time I had the front end aligned. [after I added Borgenson Power Steering]
Recently there have been threads [C1-C2] on how to increase road feel with the new Borgenson set up.
On my car I've decided to try to add caster first as a remedy.
Question, Can anybody tell me how much caster they were able to add with the Moog offset upper control arm shafts? I've read you will only gain a degree or so and I have to wonder if that is enough. I've read where you want to have 4-6 degrees.
I'm reading that slotting the shaft may be a better way to achieve the addl Caster. How much slotting would you recommend to get an additional 3-4 degrees?
As always, Thanks for the anticipated advice.
Old Sep 30, 2019 | 10:38 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Have you checked out the Global West offset upper shafts?
Old Sep 30, 2019 | 10:45 AM
karkrafter's Avatar
karkrafter
I have checked them, That is were I got the 1.25 degree figure from. Moog also makes them at a lower cost. Seems like a lot of work and expense to only pick up a degree and change...
Thinking slotting the shaft may be the way to fly...
Old Sep 30, 2019 | 11:30 AM
Fredtoo's Avatar
Fredtoo
What about something like this
https://spcalignment.com/component/s...AFrom&to=USATo
Old Sep 30, 2019 | 12:18 PM
karkrafter's Avatar
karkrafter
Originally Posted by Fredtoo
Pretty trick arms but I'd rather stay kinda stock...
Old Sep 30, 2019 | 01:28 PM
gkull's Avatar
gkull
I machined mine like this 20 years ago and I have them set to @ 6.5 castor
Not my own pictures!
Old Sep 30, 2019 | 01:31 PM
Eric P's Avatar
Eric P
the .125 is for Camber degrees … to get positive Caster you have to take/remove Shims from the front mounting stud and add them to the back mounting stud of the Control Arm … If you remove one front shim and add it to the back Shim you increased your Positive Castor with out losing your Camber adjustments , you generally take as many front shims as you can and add to the rear until you run out of Camber adjustment AKA no more shims to take out of the front to give to the back for more positive Caster , at this point Off Set Control Arm Shaft becomes valuable
Old Sep 30, 2019 | 01:33 PM
Eric P's Avatar
Eric P
[[img]https://i.postimg.cc/BvJ9hzdt/1a-Cross-shaft-machining.jpg
Fabulous way to do this !!
Old Sep 30, 2019 | 01:34 PM
karkrafter's Avatar
karkrafter
I wonder why they elongate the front hole .300 and the rear hole .250?
Old Sep 30, 2019 | 01:54 PM
gkull's Avatar
gkull
I did mine .250 each
Old Sep 30, 2019 | 02:33 PM
Eric P's Avatar
Eric P
He " Built In " .050's worth of Caster by design
Old Sep 30, 2019 | 03:24 PM
Fredtoo's Avatar
Fredtoo
I would assume to correct for the factory tolerances (slop)
Old Sep 30, 2019 | 03:30 PM
Haggisbash's Avatar
Haggisbash
I machined the stock ones by 1/4” which if I recall correctly is about as far as you can take them. One of the best modifications I have done JMPO. Running on modern tires increasing the caster made the steering feel a whole lot less nervous especially on the lumpy roads we have where I live. I would like to add the Borgeson kit but it wont pass certification here because of the welded bracket to enable it to line up with the holes in the frame rail.
Old Sep 30, 2019 | 03:41 PM
karkrafter's Avatar
karkrafter
To answer my own question, Th extra .050 must be to provide clearance to enable reeeeeeealy angling that 'A' frame to monkey with the camber.. I'm just concerned with caster. I took a quick look at what I have and yes, I'd think .250 is all you could realistically slot a factory shaft.
I'm going to slot it .250 and see what I have.
Old Sep 30, 2019 | 03:49 PM
jackson's Avatar
jackson
Most of the race car supply houses have slotted shafts & ovoid slugs with bolt holes in varied locations ...
... change out the slugs for whatever caster is required ... that's how all the "stock" cars do it.
-edit-
similar to these
https://keysermanufacturing.com/prod...ss-shaft-assy/
https://keysermanufacturing.com/prod...highlight=slug
http://www.ubmachine.com/upperparts.html
Old Sep 30, 2019 | 04:03 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Moving the ball joint back 1/4 inch would give you the caster you want. GKull did that by moving the inside a-arm mounting point backward 1/4 inch. Very cool mod!
Less expensive and more stock looking than custom a-arms. The 0-1 degree caster was there to accommodate manual steering.With power steering you are not limited to arm strength and can use 4-6 degrees caster like you mentioned and there are great tactile handling steering wheel feedback or "feel" benefits as well as self-centering benefits. At 200MPH, or auto-cross, it is very important to be able to feel what the tire is doing regarding slip-angle. The self centering eliminates the "wander" you feel at stock speeds, it just feels more stable.
Another "must-do" mod for my car!
Old Sep 30, 2019 | 04:07 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Originally Posted by Haggisbash
....I would like to add the Borgeson kit but it wont pass certification here because of the welded bracket to enable it to line up with the holes in the frame rail.
You do know the bracket is not required for the borgenson? It is an extra, for racing. The box bolts to the stock rail holes without out any additional bracket, no welding required.
To Need to add Caster...How?
Old Sep 30, 2019 | 07:07 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's the way to go with the stock UCA mounts.
I'm not a big fan of just swapping F&R shims. That method gets the desired static caster (great for driving in straight lines), but during cornering the odd angle of the UCA tends to reduce the caster and camber of the outside wheel, reducing grip.
(I've got a C4 suspension on mine, I just welded up a custom UCA mount to move the UCAs rearward to get the same benefits that your slotted shafts offer on the stock C3 mounts.)
Old Sep 30, 2019 | 07:44 PM
DC3's Avatar
DC3
I just recently finished up installing some new upper control arms from Global West. The specs state over 5 degrees of positive caster. Haven't had a chance to get it properly aligned yet but the difference in feel is amazing. The swap was fairly straight forward and I had no issues.
These are the arms I installed: https://www.globalwest.net/corvette-...5-1976-19.html
DC
Old Sep 30, 2019 | 08:21 PM
'75's Avatar
'75
In the thread where those pictures originated, the shaft holes did not match the car, therefor one slot was machined more than the other to help with the bolt alignment and give both .250" of movement.
