Factory tire rim width
Old Oct 3, 2019 | 08:35 PM
Silver72's Avatar
Silver72
Default Factory tire rim width
Could someone tell me the factory rim width for a '72 SB?
Thanks,
Steve
Old Oct 3, 2019 | 09:17 PM
BarryB72's Avatar
BarryB72
8 inch rims.
Old Oct 3, 2019 | 10:37 PM
CanadaGrant's Avatar
CanadaGrant
68's had 7 inch then every C3 after had 8's.
Old Oct 4, 2019 | 07:17 AM
Silver72's Avatar
Silver72
Default How about these?
So no go on these?
https://www.cokertire.com/p215-70r15...h-t-a-rwl.html
Old Oct 4, 2019 | 10:02 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
That tire is outside of the recommended rim width. Use them if you like the ricer pinched tire look. Otherwise, put a 60 series tire on there like this:
https://www.cokertire.com/tires/bran...h-t-a-rwl.html
Old Oct 4, 2019 | 12:38 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Yes that's a correct size. That is the close to the factory size.
Tire rack suggests 205 75/15
Old Oct 4, 2019 | 05:38 PM
PeteZO6's Avatar
PeteZO6
The optional “big” tire for 78 through 82 Corvettes was P255/60R15. I’ve been running that size on my 69 since they first became available. First Goodyear Eagle GTs, then B.F. Goodrich Radial T/As when the Eagle GTs were discontinued.
On some year Corvettes there might be a small interference when the front tires are steered left or right. A bit of fiberglass trimming would be needed in that case. They fit my 69 perfectly, and look good, not too skinny, not too wide.
Model year 1978 was the first year Chevrolet used the modern metric tire designations. Prior to that a letter designation like F70x15 was used on C3s.
Old Oct 4, 2019 | 08:28 PM
Rescue Rogers
tthe tire selector for your year came up with thosee tires and others on the Coker site. Its the closest your going to get without paying through the nose
https://www.cokertire.com/amfinder/i...der_id=4143298
double the rice for the factory size
https://www.cokertire.com/amfinder/i...der_id=4142962
To Factory tire rim width
