Hello everyone, new to the corvette forum. Recently bought my uncles '69 Stingray after wanting it since I was a kid. I am doing some basic maintenance like changing fluids in the rear end and trans. There is just one bolt on the passenger side of the transmission and when I tried to remove it, it does not want to loosen up, so I stopped pulling on it and sprayed it with PB blaster and letting it set overnight. My question sounds stupid but I just want to make sure so I don't damage it. Is the bolt right hand thread or left hand? I think it is right handed but just want to make sure. My uncle has had this stingray since it was new and it only has 31K miles on it and I don't want to mess it up.
Thanks for your help.
It's standard right hand thread. My 69 was also in tight so I tapped on the end of the wrench while putting pressure on it just to shock the plug and it came right out.
Recently bought my uncles '69 Stingray after wanting it since I was a kid. My uncle has had this stingray since it was new and it only has 31K miles on it and I don't want to mess it up.
when ever I get a bolt or plug that doesn't want to come out I tighten it a little(sometimes with a hammer to the wrench) then loosen,that usually works.
