If anyone has a copy of Desktop Dyno (I know it may be a bit antiquated) or want to take a guess, I would be interested in your thoughts on the following combo (no need to nitpick it... I didn't build it. It's in a car I am looking at):
I would imagine mid 500ish with that setup. I think the intake will hold it back a little bit, but not a whole lot. It's not a badly matched setup in my opinion.
Drop VortecPro (Mark) a line......he is a member here and enginehead extraordinaire........he did a combo like the one you are suggesting and if I remember it made like 550 hp.......how he did it through that god awful intake is beyond me.......
Thanks guys. In my head, I figured it would be close to 500 hp if tuned correctly. Yes, the low-rise intake is awful, but what else fits under a stock '71 BB hood?
That's a pretty strong street cam, and those heads actually flow pretty well. I vote for nearer to 550HP. Even with the LS6 intake. Have seen several dyno'd in that range with similar size cam.
Curious. What kind of idle rpm and vacuum do you get? 8-900?
12?
12?
Sorry, I can't answer your questions. This is the engine combo in a car I am interested in purchasing. Roughly 1800 miles on the sorted combo. It's been a long time since I have played with a BBC, so I thought I'd ask the experts here.
That is a big cylinder head, 320 cc intake runner, that may be too much head for what you are doing. I had a set of AFR 305 rec ports on my 468 and i made 708 HP with them. Mind you i built a 12-1 motor with a big solid roller, looking back i should have had a 320 cc head.
My 427 BBC +.060= 440 had 11.25-1 compression, EDDY rpm performer oval port heads, 280 cc runner. .585/.585 with .245/.255@.050 0n a 112LSa Hyd roller. made 550 hp and 513 tq. Strip dominator intake and an 850 dbl. Had a nice idle to it drove well on the street very responsive.
Honestly it it was my Motor, i would go with a set of cast iron 990 rec ports, your cam is fine, intake i imagine is for fitment issues? Look for a 780 holley with dual metering blocks and vacuum secondaries and a 1-7/8 primary tube header. That would be a nice street motor.
Grumpy... thanks for your thoughts and insight. I love the AFR 305s and built a motor 15 years ago with those heads (they were pretty new on the scene at the time). I dug this up from a post I made here when I just finished that setup back in '04:
these numbers at the rear wheels would probably be ~520hp at the flywheel. I would _think_ that the above combo I mentioned in the OP would be pretty close. Larger cam, little higher compression, but inferior intake and smaller carb. Head flow at lower lift/duration may be a wash, although I'm a big fan of AFRs and how they create airflow velocity very efficiently. I haven't driven the car yet... I am considering purchasing the car that has the combo mentioned in the OP. If I do, then I most likely will get an L88 hood, and then have some quality options to run a better intake and swap the heads for something you mentioned, or another set of AFR305's. That being said, if the OP combo is already at/near the level of the engine I built in '04... I'm not sure it is worth all that expense. I would not be looking to build anything close to what you have. That's for another car in my garage.
Sounds like a nice setup.
If I were you, I would start a new thread and ask which intakes would work well with your build and still fit under your hood.
I've read on several threads where members were running Edelbrocks, Weiands, and others under the stock earlier hoods.
You might need a drop base air filter, but a different intake might give you some additional hp.
Those heads have bad reps for the cheapass valves and springs they throw in them. They flow good and make good power. A guy near me bought a 496 with the same heads. Dropped an intake valve head at IDLE! Busted block and ate one head. He was asking 3k. He got 500. If heads were bought complete and assembled, pull them and replace the valves with Ferrea or some other quality valve. That motor should do 525-550 pretty easy.
If I buy the car and pull the heads, I'm putting some AFRs on it.
