Heater issue
I took some measurements with an infrared thermometer. If I let the car warm up in the driveway, the heater hoses are about 170 (my thermostat is 180). The hoses feel hot and firm like they have some pressure to them. This is when the heater blows hot.
Once I drive it around, however, it cools off. The readings on the same hoses are then about 110-120 on the hose coming from the intake manifold. This reading is near the firewall and is the same before and after the heater valve. The hose doesn't feel like it has the same pressure it did when it was hotter. Also the temperature near the intake manifold outlet is warmer, about 150. Thoughts? Is that a bad thermostat? The temp gauge reads about 180.
Thanks in advance,
Ivan
my guess is the the valve that controls the water flow to the heater core is failing and allowing water to flow to it all the time regardless of the heat setting
