Headlights won’t stay down
Old Oct 15, 2019 | 03:23 AM
Nathan Weaver's Avatar
Nathan Weaver
Default Headlights won’t stay down
Can somebody help me please, I’ve replaced my relays, seals and my switch holds vacuum on its own but when I connect to the relay and I pull my lights on the headlights go up but when I turn off they go down but then start to come back up again. I just don’t understand what’s going on?? It’s for my 1982 corvette.
Old Oct 16, 2019 | 06:32 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would say you have a vacuum leak . Do you have a mighty vac to test them with, or a vacuum gauge. What the cause could be is that when you turn off the light switch, its telliing the system to pull vacuum on the "close side of the actuator, when you shut off the car the vacuum is slowly leaking off on the close side and the open side is overpowering that side of the actuator
