Alternator bracket
Old Nov 14, 2002 | 09:45 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Alternator bracket
I'm sick and tired of these cheesy disount auto store alternator brackets that work with headers. I have tried the no-name and then the chrome Mr. Gasket. The first one broke and now this one is slowly bending....making the belt squeal. I've seem some of the cool billet ones but sell for over $100. Do any of you know of a good, inexpensive bracket? This is the best deal I've found so far:
http://www.zigsstreetrods.com/Pages/brackets.html
I'm speaking of the bare steel bracket for $84.95.
Old Nov 14, 2002 | 09:50 AM
Fevre's Avatar
Fevre
Default Re: Alternator bracket (tshort)
Get an alum one from a vette parts vendor, it bolts flat to the front of the driver's side head. Also get the upper bracket because it shaped a little diff than those one you get at the parts store. I think they are about $60 total together.
Alwyn678's Avatar
Alwyn678
I would go and spend 7 to 12 bucks at the Chevrolet Dealership and good a Good GENUINE GM part.......I did and NO MORE PROBLEMS
Old Nov 14, 2002 | 10:23 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Alternator bracket (Alwyn678)
Fevre - a vette parts vendor??? Do you know of a specific one or a link?
Alwyn678 - I would go the stock route but I don't believe it will work since I have headers. Thanks for the suggestion though.
Old Nov 14, 2002 | 10:41 AM
Alwyn678's Avatar
Alwyn678
Works Great with my Dynomax headers.... :cheers:
Old Nov 14, 2002 | 10:43 AM
Fevre's Avatar
Fevre
I see it listed in ZIP's section:
http://store.yahoo.com/zipproducts/e...-brackets.html
I believe you need the 'brace' and 'bracket' for the 2nd design. I can check the part number on mine at lunch but it is alum so I think it is the 2nd design bracket.
Old Nov 14, 2002 | 12:43 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
They make 2 different models of the later C-3 Alternator bracket, one is cast iron and the other is cast aluminum. I bought the cast aluminum one, it was more expensive than the cast iron one, but it looks better than the cast iron one would next to my aluminum heads, on my ZZ-4. You'll also need the top brace as the old type probably won't work. Check the Zip catalog pages and you'll see both types listed.
The Aluminum one looks pretty good and is a "Genuine GM Reproduction Part"
Old Nov 14, 2002 | 01:45 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Alternator bracket (Fevre)
The one from ZIP propably wouldn't work for me... They are setup to put the alternator in the correct location for a Corvette setup.. However - my engine doesn't have any Corvette parts... only chevy parts.. so I need a Non-Corvette bracket... I'm sick of my alternator brackets breaking... :mad
:cheers:
Olivier
Old Nov 14, 2002 | 02:37 PM
GrandSportC3
I just browsed through the Summit and Jegs catalogs and found this bracket:
http://www.jegs.com/cgi-bin/ncommerc...76&prmenbr=361
It says that the alternator mount is pretty high and the it might not cars with low hood clearance... I wonder if it fits a Vette....
:cheers:
Olivier
Old Nov 14, 2002 | 02:43 PM
Fevre's Avatar
Fevre
Default Re: Alternator bracket (GrandSportC3)
Looks like it bolts on the passenger side. Nice looking though.
Old Nov 14, 2002 | 02:45 PM
GrandSportC3
The image might be mirrored... I have seen this already several times...
:cheers:
Olivier
Old Nov 14, 2002 | 03:41 PM
GrandSportC3
Here is another interesting bracket:
http://www.billetspecialties.com/ite...scid=5&pid=141
:cheers:
Olivier
Old Nov 14, 2002 | 04:28 PM
Barry's70LT1's Avatar
Barry's70LT1
Short and simple.
I installed headers over 30 years ago.
I used a GM CAST steel bracket that bolts to the head.
No other parts required. Used existing top brace, pulleys/belts lined up fine.
Been working for over 30 years.
Old Nov 15, 2002 | 01:39 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Alternator bracket (Barry's70LT1)
Yeah, but can you still buy one of those? I've looked in Eckler's and some of the other catalogues and the GM bracket won't work with headers.
Old Nov 15, 2002 | 02:08 PM
Fevre's Avatar
Fevre
Which bracket you looking at? Mine works fine with headers. It bolts flat to the front of the head.
This is what you need:
http://www.ecklers.com/product.asp?dept%5Fid=1198&pf%
Sorry ZIP, you should have a picture online.
Don't forget this:
it is a little diff than the one you get a the parts store.
[Modified by Fevre, 1:11 PM 11/15/2002]
Old Nov 15, 2002 | 08:45 PM
Barry's70LT1
My bracket looks like this as well. WORKS with headers.
Not sure if it is still available from GM. In 1971, it was used on pick-up trucks.
Thats where I first saw one.
Old Nov 15, 2002 | 10:07 PM
Smokehouse69
That's like the one I bought from Zip, it came with a GM Parts number and sticker, so I guess it is probably still available from a Chevy dealer. One thing is, it won't work with 69 ramshorn manifolds that had the old style alternator mount that bolted to the manifold. It should work fine with headers since it has no involvement with the headers at all.
I was in Autozone today and saw an alternator mount made by Spectre (?) it was a chrome plated two piece affair, that looked pretty solid. I have no idea how well it would work, it looked more substantial that the other ones I've seen in the parts stores.
To Alternator bracket
