How Much Is This Worth?
Old Nov 14, 2002 | 10:18 AM
bence13_33's Avatar
bence13_33
Default How Much Is This Worth?
I have a 3.36 rear end laying around that I would like to sell. The rear end only has 23,000 miles on it. It is a complete rear end with side yokes, driveshaft yoke and differential cover. What would be a fair price to ask for something of this nature?
I also have one good big block exhaust manifold. The exhaust manifold is off of a '73 LS4 454 Corvette. How much is something like that worth?
Thanks.
Old Nov 14, 2002 | 10:24 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: How Much Is This Worth? (bence13_33)
It' worth $100! Where should I send the check :jester :jester
Well - the actual value is probably closer to $500 - $600.. maybe even more...
I might need a new rear end soon if I continue running Drag Radials...
:cheers:
Olivier
Old Nov 14, 2002 | 10:38 AM
GrandSportC3
I just checked on Ebay... and I found a 63 - 79 rear end with 4.56 gears that has a "BUY IT NOW" price of $499...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872269040
:cheers:
Olivier
[Modified by GrandSportC3, 10:38 AM 11/14/2002]
Old Nov 14, 2002 | 10:41 AM
bence13_33's Avatar
bence13_33
Default Re: How Much Is This Worth? (GrandSportC3)
Olivier:
So those drag radials hook that good huh? What kind of 60' times are you pulling?
The reason I'm looking at selling the rear end off is because I am saving up my money to do some more motor work. I just can't see myself ever going back to a 3.36 rear end after having felt the 4.11s with my 4 speed.
Old Nov 14, 2002 | 10:48 AM
GrandSportC3
Olivier:
My best 60' time so far was 1.676.. My "other" 60' times were in the low 1.7x's Unfortunatly I had shifting problems (clutch linkage) at this run which could have been in the 11's...
I was able to launch at 3000 RPM with NO tire spin!! :eek: :eek: :eek: . However - my clutch was not too happy about that launch - causing my problems... My other 60' times were in the 1.7x's. Unfortunately - I only got a 1.813 60' time after I adjusted my clutch linkage - preventing me from getting into 11's that time...
:cheers:
Olivier
[Modified by GrandSportC3, 10:57 AM 11/14/2002]
Old Nov 14, 2002 | 10:51 AM
GrandSportC3
You also have to consider that I'm running on one of the best tracks in the US.. The pour lots of VHT on the track.. It grips like crazy!!!
:cheers:
Olivier
Old Nov 14, 2002 | 12:41 PM
ML67's Avatar
ML67
Shane,
You have mail. It is in your best interest to read it.
Mark
Old Nov 14, 2002 | 12:44 PM
bence13_33's Avatar
bence13_33
Default Re: How Much Is This Worth? (ML67)
Mark:
You have mail.
To How Much Is This Worth?
