Valve spring problem on just 1 valve
Old Oct 19, 2019 | 09:10 PM
68notray's Avatar
68notray
Default Valve spring problem on just 1 valve
Needing advice - putting together my 70 small block 186 heads. Obviously 50 ys old and a few valve jobs - I have 1 exhaust valve seat a little "sunk", so that particular spring installed height needs an extra .060 shim in comparison to the others. Well - it is the outermost spring in the head - the one that has the least casting around the spring seat. That extra shim eliminates all the casting lip so I've got a poorly located spring. Option 1 - eliminate the extra shim and have 1 spring a little less seat pressure. 2 - put that extra shim on top of the spring under the retainer. 3 - buy a whole set of -.050 locks and use just 1 pair. 4 - buy a whole set of seat locators and use just 1. What do you think?
Old Oct 19, 2019 | 11:54 PM
REELAV8R's Avatar
REELAV8R
Buy a valve spring locator. It will shim it up and keep the spring located.
Old Oct 20, 2019 | 12:00 AM
gkull's Avatar
gkull
You don't have a high rpm or high spring pressure. So the spring isn't going to be walking around. You could use a thicker single shim or a spring cup
Never run less pressure or shim the retainer.
I have used +.050 retaineretainers for additional spring coil bind clearance . So the-.050 is an option
Old Oct 20, 2019 | 03:44 PM
stingr69's Avatar
stingr69
Shim the bottom of the spring and forget about it.
Old Oct 20, 2019 | 04:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yep.....
Jebby
Old Oct 20, 2019 | 06:12 PM
derekderek's Avatar
derekderek
Or buy a slightly longer Spring with the similar Spring rate so it can set up closed at correct pressure with the 60 thousands bigger space.
Old Oct 21, 2019 | 01:43 PM
jackson's Avatar
jackson
cup or locator ... whichever suits your guide / pocket
https://www.enginepro.com/downloads/...ors_Guides.pdf
Old Oct 23, 2019 | 12:23 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
If you want a more permanent fix you can have new seats installed for all the valves to not only get the valve back where it belongs but the hardened seats last much longer. It all depends what you think those heads are worth to you.
Small block Chevy - options are nearly endless.
Good luck.
To Valve spring problem on just 1 valve
