Presently running a 255-60-15 Bf goodrich tires on my 73 in rear...
Have a 3:70 ratio with a 4 speed....Looking to go with a taller tire to cut down RPM on highway..Have 15X8 inch rims....
Don't want a 5 speed or the hassle of finding one and installing....Figure maybe a 275-70-15 ? Do they even make this size ? Will that fit ? 70's are a taller tire than the 60 series .... If so,who has them..?
3:70 is a great street gear...Will need new rubber sooner or later.....I think, I have to check again , the 70 series are 2 inches more in diameter...Should be good for 200-250 rpm less..
Google. Tacoma world tire calculator. It will give you tire dia. Sidewall height, circumference, how many revolutions per mile and compare it to your current tire.
a 255/60 15 is 27.05 dia. A 265/70 15 is 29.61 dia. As one example. It even shows the tires side by side for comparison as to how they would look. On an 8 inch rim your 255 has it maxed out on width it should use.
