How to adjust 1969 brake light switch
Old Oct 25, 2019 | 11:37 PM
Torquecrazy's Avatar
Torquecrazy
1st Gear
Default How to adjust 1969 brake light switch
I need to advance the brake light switch a little so brake lights turn off when foot is off the peddle. The lights stay on until I use my toe to lift the peddle a little bit. I can't get my fingers around the back of the white switch to release the second black plastic retaining clip. I need someone with really really long skinny fingers... or is there a special tool?
Old Oct 26, 2019 | 04:27 PM
MelWff's Avatar
MelWff
with the wire disconnected there should be a nut you loosen.
you then turn the switch until the switch is actuated when the pedal is pressed 1/4" to 5/"8".
then retighten the nut.
