1977 Corvette Ignition
Old Oct 27, 2019 | 10:16 PM
Smitty83's Avatar
Smitty83
1st Gear
Default 1977 Corvette Ignition
Recently got a 1977 C3. I realized you could start the car without a key. So I figured I'd replace the lock cylinder. After installing it, I cant seem to get the key to the lock position and get the key out. Any ideas?
Old Oct 27, 2019 | 10:42 PM
Vette_DD's Avatar
Vette_DD
Welcome to the forum.
My suggestion is for you to wait until a moderator moves this thread to the C3 forum so someone there can help you.
Old Oct 28, 2019 | 07:44 AM
gilhuly's Avatar
gilhuly
Welcome and good luck with your C3!
Old Oct 28, 2019 | 08:21 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome to Corvette Forum! Your question will be moved to the C3 Tech/Performance section.
Old Oct 28, 2019 | 08:55 AM
bazza77's Avatar
bazza77
The 77 column has a tab(lever) behind the key switch , you have to push and hold the tab down while turning and removing the key
To 1977 Corvette Ignition
