78 door lock actuator
Old Oct 28, 2019 | 01:06 PM
elmo771's Avatar
elmo771
Default 78 door lock actuator
Is there a trick to get the actuator rod attached to the lock pivot? I tried for 3 hours trying to get it on. I am at a stalemate.
Old Oct 28, 2019 | 06:42 PM
kanvasman's Avatar
kanvasman
Make sure you are trying to get it in the right hole...Seriously... One end of the arm in the door is round and the other end is elongated. You need to put it into the top hole. If you take the rod and start to turn it upwards, the elongated end of the rod will fit into the elongated slot. ONce it goes in and it gets into proper position, it can't fall out.
Old Oct 29, 2019 | 08:55 AM
elmo771's Avatar
elmo771
Thanks I know about the slotted hole for the actuator rod. Just can't figure out a way to install it in the pivot with the limited room inside the door. I am going to try to assemble the whole thing and try to fish it in the door. If that wont work I guess I will take the glass out and try.
Old Oct 30, 2019 | 07:17 AM
LenWoodruff's Avatar
LenWoodruff
You shouldn't have to take the glass out to get to the rod since the rod is on the inside of the glass.
When I changed my outside door handle I just raised the glass up and had complete access to everything I needed to get to.
To 78 door lock actuator
