1970 Torque Specs for A Arms
Old Nov 14, 2002 | 06:54 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default 1970 Torque Specs for A Arms
I am getting ready to set the engine in my car Friday or Saturday. I have waited until now to torque the bolts that hold the bushings in the a arms until after the engine is set in the frame. What should these bolts be torqued at? I need to know for the upper and lower control arms.
Thanks for any help you guys can give.
Old Nov 14, 2002 | 07:24 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: 1970 Torque Specs for A Arms (Eddie 96)
Eddie; I believe the uppers bolts are 55ftlb.
The lower rear was 90ftlb and the two lower front are 70-75ftlb.
Glad to hear your dropping the engine. Should haul!
:cheers:
Old Nov 15, 2002 | 07:36 AM
theandies's Avatar
theandies
Default Re: 1970 Torque Specs for A Arms (1970 Stingray)
The torque specs were in my AIM for my 71. I recently moved and have not looked for my AIM but I'll dig it up and look for you.
John
Old Nov 15, 2002 | 11:39 AM
One Bad 74's Avatar
One Bad 74
I'm getting ready to do the same thing but I was under the impression that those should be torqued down after the wheels are back on the ground (assuming you have it up on stands). That way all of the weight is on the suspension. Just a thought.
Old Nov 15, 2002 | 11:44 AM
theandies's Avatar
theandies
Default Re: 1970 Torque Specs for A Arms (One Bad 74)
You are correct sir. The AIM says to torque them with the car a ride height. Thats how I did mine.
John
Old Nov 15, 2002 | 02:06 PM
Eddie 70's Avatar
Eddie 70
Default Re: 1970 Torque Specs for A Arms (theandies)
I guess I could have been a little clearer. My car is on the ground but still doesn`t have the motor in yet. When the motor gets home that is when I will do the torqueing. I just wanted to get the numbers ahead of time.
Good luck One Bad 74.
I have the motor hanging on the engine puller and the transmission attatched. It should be in sometime a little later this afternoon. :smash:
[Modified by Eddie 96, 2:07 PM 11/15/2002]
Old Nov 15, 2002 | 08:43 PM
Eddie 70's Avatar
Eddie 70
Hey guys thanks for the help. I got the arms torqued. That means the motor is in. But that is it. Still got to put the radiator support and all the radiator stuff in. I am pretty stoked at this point.
BTW, this is me right about now, :cheers:
Old Nov 17, 2002 | 09:04 AM
theandies's Avatar
theandies
What torque spec did you use? I found my AIM and it says for the bushing bolts (lower) is 45 to 55 lb/ft. The lower arm frame attachment bolts 75 to 110 ft/lb for the rear one and 60 to 80 ft/lbs for the front ones. The upper control arm attachment bolts (where the front end alignment shims go) are 45 to 55 lb/ft. There was no spec for the upper control arm bushing bolts in the AIM so I used the lower spec on all bushing bolts.
John
Old Nov 17, 2002 | 09:08 AM
Eddie 70's Avatar
Eddie 70
I did the same as you did John.
Not running yet, but I just keep going out and tinkering with it. Kinda cool out in the garage.
To 1970 Torque Specs for A Arms
