Intake Fit?
Old Nov 14, 2002 | 09:45 PM
boredsoIstrokedit's Avatar
boredsoIstrokedit
Default Intake Fit?
Tried searching, couldn't find what I was looking for. Does anybody know if a Weiand Stealth will fit under the stock 80 hood? Or, what intakes have you guys used that will fit. Someday would like to get a hi-rise hood, just want to make if faster first. $500 buys quite a few ponies :yesnod:
Old Nov 14, 2002 | 10:17 PM
81Vette_by_eric's Avatar
81Vette_by_eric
Default Re: Intake Fit? (boredsoIstrokedit)
am i reading that right....you have a 4.55 rear gear....holy snikes batman :bb
Old Nov 14, 2002 | 10:20 PM
DollaGreen's Avatar
DollaGreen
Default Re: Intake Fit? (81Vette_by_eric)
QUOTE: "am i reading that right....you have a 4.55 rear gear....holy snikes batman "
Thats like 4 wheel low on my Expo.
Old Nov 14, 2002 | 10:24 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I've got a Weiand Stealth under a stock '71 - you shouldn't have any problems with yours. :cheers:
Old Nov 14, 2002 | 10:29 PM
BSiegPaint's Avatar
BSiegPaint
Sending you some pics -
Old Nov 14, 2002 | 10:37 PM
boredsoIstrokedit
Yep 4.55 :) 2000 rpm's at 70. Thanks guys, I am always amazed how fast responses can come.
Old Nov 14, 2002 | 10:39 PM
BSiegPaint's Avatar
BSiegPaint
Bounce, bounce, bounce, bounce... can't get pics to go through to you! I guess you'll have to trust me? :blueangel:
Old Nov 14, 2002 | 10:40 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I use a Edelbrock Tarantula (TM-1) which is approx. the same height as a stealth + a 1/2 inch spacer under a stock height hood... However - I use a extreme air filter drop base setup...
:cheers:
Olivier
[Modified by GrandSportC3, 10:41 PM 11/14/2002]
Old Nov 14, 2002 | 11:02 PM
boredsoIstrokedit
Default Re: Intake Fit? (GrandSportC3)
How much was the drop base air cleaner, and where did you get it? Thanks, Chuck
Old Nov 16, 2002 | 06:02 PM
The Money Pit's Avatar
The Money Pit
Default Re: Intake Fit? (BSiegPaint)
I've run the Performer and the Performer RPM Q-Jet on mine. Had to switch to a three inch filter element with the high rise,but there's room with the stock 80 hood.
To Intake Fit?
