Ok, now so just WHAT IS IT???????
Old Nov 15, 2002 | 04:57 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Ok, now so just WHAT IS IT??????? (Fevre)
The volume of any cylinder is PI (3.1416) times the radius squared times the height. So we have PI x R (squared) x H for the volume of ONE cylinder. "R", the radius, is 1/2 of the diameter of the cylinder and "H" is the stroke.
Take that result times 8 for an eight cyl. car, 6 for a 6 banger, and so on. See what I remembered from high school algebra and trig. :) Chuck
Old Nov 15, 2002 | 05:14 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Ok, now so just WHAT IS IT??????? (Chuck Gongloff)
That's how I got my numbers.. I paid attention in school... :yesnod: :yesnod: even though it 10 years ago since I graduated...
:cheers:
Olivier
Old Nov 15, 2002 | 05:45 PM
Schmucker's Avatar
Schmucker
Default Re: Ok, now so just WHAT IS IT??????? (SanDiegoPaul)
385. I'd rather just go .020 over, then if I wear it out, go .040 over, then .060 over. Rather than just .030 than .060. Blocks clean up under .020 usually.
Old Nov 15, 2002 | 09:37 PM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Ok, now so just WHAT IS IT??????? (Desertdawg)
384.6
Wouldn't it be a 394 :confused:
So I guessed.. Sue me. :lol: :lol: :lol:
No wonder the checkbook never works right... :eek:
Clink69's Avatar
Clink69
Actually its :
2(pie).h
)..........) r*dr*dh (the integral for 1 cylinder)
0.........0
disp1= 2(pie)r**2 * h
.............--------------.............= ((pie)r**2) *h
.......................2
disp1= ((pie)*r**2) * h (for 1 cylinder)
disp8= ((pie) *r**2)*h*8 (for 8 cylinders)
so for stroke = h= 3.75in
r= 4.03in/2=2.015
disp8=(3.14159*2.015in**2)*3.75in*8 = 382.67in**2
chris
:flag
Old Nov 16, 2002 | 04:22 AM
Chuck Gongloff
Default Re: Ok, now so just WHAT IS IT??????? (GrandSportC3)
You're all a bunch of "young whipper-snappers". :) I was real proud of myself, since I graduated 38 years ago :) (High School, that it) Lots of dead brain cells since then. Mr. Tucciarone, my HS teacher would be proud. Chuck
Old Nov 17, 2002 | 01:40 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
All I know is that a normal stroked 350 with a 400 crank is a 377 with a standard bore (4.0) and is only a 383 if you bore .30 over. A .30 over bore is usuall because you are usually making a stroker out of a used motor so you need to bore it out anyway.
Old Nov 17, 2002 | 01:46 AM
Schmucker's Avatar
Schmucker
http://www.airflowresearch.com/artic...le03/A3-P1.htm
Just a neat article about using long rods (Ford 300CI I6 rods in a Chevy to be exact)
