I have a new 1970 Corvette gas tank purchased before I decided to install a Holley Sniper EFI system with pump and such. My understanding is that the Holley EFI needs a 3/8" Return line and the tank I have is either 5/16" or 1/4" return, smaller on the pre-purchased tank.
I'm thinking of just increasing the Return line opening to 3/8" on the tank by a local company or is it technically not advisable ?
As the owner of a '70 as well, I've got a question. '70's (and earlier maybe later) have supply and return lines on the tanks bottom. Does this come into play with EFI conversions? I know it does with 'in tank' return less systems because you cant mount the pickup/pump upside down.
The new EFI setups can generally be run either way. In tank pump with a return line is typically better, but many run out of tank pumps and many run without a return line. Without a return line definitely works depending upon your EFI setup, but the chances of vapor lock don't go away totally as they pretty much do with a return line and an in tank pump.
Depends....some of the newer EFI you dont have to run a return all the way down to the engine. However most you do (minus anything LS of course). I personally ran all new lines on mine. You can run the Russel PTFE stuff, no need to fight with metal lines. It's what I've done on a few cars. If you running anything with pressure I wouldn't trust a 50+ year old line...you can get away with it on the return if you must but if your under the car anyway why cut that corner??
Thanks.
Yes you can have the return enlarged to 3/8, it will work fine. T
I installed a Sniper over the summer on my 69 with a new EFI Tank. I ran a new Line and used the Original as the Return Line. I also ran the Power wire for the Fuel pump through the no longer used Vapor line. It worked out really well but I'll say getting that wire through to the back was not very fun.
Even better, Holley now makes this fuel pump module. It installs in place of your sender, is preset at 58psi with the regulator bypassing fuel into the tank and a special sock that creates a small fuel reserve to avoid cavitation. This is what you want to use!
Run new lines, plug up one of them, and then do use the Holley Kit. You will have a return already in place if you decide you want something else later and save the expense of a new Tanks tank, pump, sender, etc. It took maybe an hour to install the Holley module.
I chose to go with the Holley EFI in tank unit 12-311 which will allow me to utilize my tank, along with running a new supply & future return (never hurts).
Thanks to all !
I'll post on my build thread the installation.
Flyeri can you clarify if the pump can be intalled without dropping the tank?
Thanks much. Dave
Yes it can. I just recently installed one in my 72. Took my time and was very careful. Went in pretty slick. Can't tell you how it runs yet, as I'm still completing wiring, fuel line, etc... Hardest part so far: pumping out the gas in the tank!!
Thanks much. Dave
It certainly can be installed without dropping the tank. Read the instructions carefully. You have to take the float lever off to get the pump in. Then insert float and lever into the hole and reattach to assembly.
Thanks to all !
Be sure to check inside your tank. I found silver like material in the QJets fuel filter, its from the tanks inside coating flaking off. I'd need a new tank...
