Fixing heater core?
Old Nov 1, 2019 | 09:20 AM
kodpkd's Avatar
kodpkd
Default Fixing heater core?
Has anybody fixed their leaking heater core? As in resoldering it.
Old Nov 1, 2019 | 10:19 AM
Tampa Jerry's Avatar
Tampa Jerry
Don't even think about fixing a heater core. It is such a pain in the butt to change. If it has weakened walls and leaks, it will leak in another spot in short order. I even go so far as to check a new core for leaks before I install it. Jerry
Old Nov 1, 2019 | 12:06 PM
kodpkd's Avatar
kodpkd
Default Go new.
Thank you,,, is where I am leaning. For $50 bucks, and piece of mind, go new. Mine is non A/C, so not to bad removing from the firewall side.
Old Nov 1, 2019 | 12:59 PM
Little Mouse's Avatar
Little Mouse
remove it wear a jacket if need be and it will never leak again. Lol im riding my motorcycle every day in the texas winter. Surely a jacket good enough for you with no wind chill factor.
Old Nov 1, 2019 | 03:06 PM
jackson's Avatar
jackson
Get a new heater core But first take new heater core to a rad pro and have them pressure test & add solder as needed ... don't scrap the old one ... it my be worth fixing.
Also install w/ a stainless 1/4-turn ball valve on both hoses.
Old Nov 1, 2019 | 06:39 PM
kodpkd's Avatar
kodpkd
Heater core is remover. Fan shroud all cleaned up, ready for the new core arriving tomorrow. So much black crap stuck all over the place, geeeez! I am going to install a shutoff valve in the heater hose. When it's hotter than H next summer,,,, at least I will know it isn't coming from the heater.
Old Nov 2, 2019 | 08:09 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
YOu can find out how much recoring would cost at a radiator shop. If you go new, go to harrisons website to see if you can find an exact fit. New ones from part supplier are a close fit. Depending on where you live , the coat is an option, I'm goiing to a show in less than an hour and its still below freezing out......brrrrr
Old Nov 2, 2019 | 08:51 AM
derekderek's Avatar
derekderek
Radiators get hurt. Stone punches a hole. You can fix it. Nothing can hit a heater core to make it leak. Nothing but air and antifreeze. If that makes it leak in one spot, it is gonna leak everywhere. Especially right next to where you soldered it up..
Old Nov 2, 2019 | 01:12 PM
Taijutsu's Avatar
Taijutsu
Default 3 core to a 4 core.
I went from a 3 core to a 4 core and it worked well!
The Spal fans also helped!
Old Nov 2, 2019 | 01:35 PM
jackson's Avatar
jackson
One valve all but stops flow and leaves cabin noticeably cooler ... but ...
... two valves will also allow you to completely isolate the core in just a minute or two ... handy if/when core pukes.
Old Nov 2, 2019 | 08:06 PM
kodpkd's Avatar
kodpkd
Done,,,, Love having my car like it is supposed to be,,,, with a heater. For the DIY'ers. It is an easy fix for NON A/C cars. Change it from under the hood at the firewall. When you get the fan/heater cover off,, you will see the heater core. It is a pain to get out. Use a grinder and grind the upper and lower edge of the opening. Maybe just 1/8 inch on each edge. This way it will come out MUCH easier,,,, and install easier. Clean up the edges of the cover and the mateing surface on the firewall. The clip that holds the core in, on the pax side has 2 grips that need to be lifted so it can be removed. Don't just pull on it,,,, it will break. A small screw driver works well. I looked online at a new clip to see how it's removed. Next get some Butyl sealant tape. Very sticky and strong to seal the cover back onto the firewall. No need to make a mess with RTV. When you have the cover off,,, be careful with the box the core sets into. With the 6 bolts removed from the cover the inside box is loose. I was able to reuse the big rubber seal at the 2 tubes.
Old Nov 2, 2019 | 08:59 PM
interpon's Avatar
interpon
Just did mine with ac..long thread on it..
i did find one place that would fix and or replace fins depending on condition..100 to 180 bucks.
new 80 bucks made in mexico from a sponsored supplier..and yes i would leak check at home with compressor and bubbles as mine leaked after tweaking.
i saved the old core and radiator..just in case..of what i have no idea ... it sits with ac compressor in another box.
To Fixing heater core?
