Emergency Brake cable "mickey mouse" clips do not hold
Old Nov 3, 2019 | 03:25 PM
Lagonia's Avatar
Lagonia
Default Emergency Brake cable "mickey mouse" clips do not hold
I have done a complete rebuild (among other things) of the emergency brake subsystem on my 79 L82 but it turns out that the e-brake does not work -. going through the trouble shooting procedure I realized that the e-brake levers on one wheel would not move at all and on the other wheel barely moved. It turns out that the brand new clips that supposed to hold the brake cable together just pop - they do not have the holding power. All the parts were purchased from a well known online Corvette parts dealer.
Question is whether I got a batch of bad clips, is this a known weakness in the system and whether there is a better solution out there? I just took a video and will post it next
Thanks.
Old Nov 3, 2019 | 03:38 PM
Duke94's Avatar
Duke94
I couldn't get the mickey mouse clip to work either. Bought the stamped steel kind at the local parts store....problem solved.
Old Nov 3, 2019 | 03:44 PM
Lagonia's Avatar
Lagonia
Thanks Duke, do you recall what size they were or do you have link/part number? Thanks.
Old Nov 3, 2019 | 03:45 PM
teamo's Avatar
teamo
My Mickey clips went in tight and hold the cable to the bracket fine.
Old Nov 3, 2019 | 04:04 PM
Lagonia's Avatar
Lagonia
Of the 4 brackets that hold the parking brake cable in place (2 on each side) only 1 works. It is the only one that seems to have a completely flat surface - all the other brackets are slightly bend and they do not provide a flat surface for the cable and the brake cable clips to mate properly allowing, therefore, for movement... it looks like replacement brackets are available - two of them I would have to cut off and have the new ones welded on...
Old Nov 3, 2019 | 05:44 PM
Mooser's Avatar
Mooser
I ground the sides of the clips down a little on the replacement ones I bought and they fit into the groove and hold tight, before that when the T/A moved it would pop one side out
M
Old Nov 3, 2019 | 07:50 PM
Peterbuilt's Avatar
Peterbuilt
Today I had the same problem reinstalling the mickey mouse clips, they just popped off or caught on one side just waiting to pop off, so I need a solution too!
I could use a photo or description of how the parking brake cable looks installed from on the end with the ball to where the spring goes and where the rubber goes.
Thanks, Pete.
Old Nov 3, 2019 | 08:56 PM
Mooser's Avatar
Mooser
Either of these help?
It's a test fit of the relocated bracket onto the top of the TA with the old boot but you get the idea
M
Old Nov 3, 2019 | 08:59 PM
Mooser's Avatar
Mooser
Alan's boot
https://www.corvetteforum.com/forums...post1595671279
M
Old Nov 3, 2019 | 11:55 PM
Peterbuilt's Avatar
Peterbuilt
Thank M,
That is exactly the information I needed to reassemble the parking brake.
Only working on Sundays, four weeks ago I started to replace the trailing arm and strut rod bushings
Took the trailing arms to 'Dub' and he installed new rubber bushings.
Third Sunday got the TA and both strut rods back on the car.
The strut rods are aftermarket so poly went back in them.
Today I reinstalled the calipers and brake fluid lines and that's done.
So thanks to your pictures I will push on!
I'm missing the WHITE plastic part, (where the cable goes into the bracket) is that necessary?
Best Regards, Pete.
Old Nov 4, 2019 | 06:48 AM
Mooser's Avatar
Mooser
Originally Posted by Peterbuilt
Thank M,
... I'm missing the WHITE plastic part, (where the cable goes into the bracket) is that necessary?
It's there to allow the inner cable to slide on the steel bracket without wearing it away. Chances are you're not using the parking brake much (if at all) so the wear won't be an issue. I'd say go ahead you can always add it alter on when you get one
M
Old Nov 4, 2019 | 07:38 AM
interpon's Avatar
interpon
Thanks all for pictures, very helpful, I appreciate it..glad op on track i just did this and appreciated op help too. Luckily i didn’t need to mess with cable and lubed the parts past ball pull..
again thanks..had no clue mickey mouse...
Old Nov 4, 2019 | 01:10 PM
80-Vette's Avatar
80-Vette
Thanks, that picture is exactly what I needed.
To Emergency Brake cable "mickey mouse" clips do not hold
