gas gage is pegged
Old Nov 15, 2019 | 11:13 AM
CiCiC3's Avatar
CiCiC3
Default gas gage is pegged
After reinstalling and connecting the fuel sending unit I reconnected the battery and then turn the ignition switch to ON. I then noticed the fuel gage to be fully pegged and after disconnecting everything again it remains in the peg position. So I need to reset it and correct what may have caused it. Any ideas?
Old Nov 15, 2019 | 12:06 PM
OldCarBum's Avatar
OldCarBum
Is your gas tank full?
Ok, I was being a smart a$$!
Old Nov 15, 2019 | 12:14 PM
HeadsU.P.'s Avatar
HeadsU.P.
No expert on gauges but I seem to recall an old phrase that when any gauge is pegged, wither its gas gauge, voltage, oil or water temp gauge, it means its not grounded properly. In other words, no resistance because of no complete circuit.
Old Nov 15, 2019 | 12:23 PM
CiCiC3's Avatar
CiCiC3
Yes thanks, I was just reading that on someone else post who is also having gage problems. I think I might be short circuiting the ground on the lock ring on the fuel sending unit and that might have the same result. Probably should take picture of it and post it on here. Thanks
Old Nov 15, 2019 | 12:52 PM
CiCiC3's Avatar
CiCiC3
There might be something that is not supposed to be touching causing short-circuit?
Old Nov 15, 2019 | 01:12 PM
HeadsU.P.'s Avatar
HeadsU.P.
H-m-m-m. Not sure. But to me a short circuit is positive to ground, resulting in sparks, blown fuses and the like. I think your gauge is getting 12V but is NOT getting a good ground. But where? IDK
The gauge right out of the box was at zero / empty correct? Then you hooked it up and it pegged?
Old Nov 15, 2019 | 01:52 PM
wendellp601's Avatar
wendellp601
Fuel gauge pegged at FULL indicates a missing Ohm signal from the sender.
Here's a link to the Willcox site.
http://repairs.willcoxcorvette.com/1...-can-tell-you/
Old Nov 15, 2019 | 01:55 PM
Jeffs82c3's Avatar
Jeffs82c3
Old Nov 15, 2019 | 02:15 PM
CiCiC3's Avatar
CiCiC3
Yes it was zero but I'm not sure when it pegged when I connected the battery again or when I switched it to ON. Anyway I might need to clean up the ground wire tab and wire clip on. What actually resets the gage though.?
Old Nov 15, 2019 | 02:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
Resets the gauge? I would think when power is truely removed, the needle should go to empty, I guess. So now I wonder if that circuit truely does go dead when you turn the IGN off. Now I suspect the sending unit instead of the gauge.
So the new question is how does a fuel tank sending unit ground itself? Maybe trace the wiring back from the tank as far as GM will allow you too before its hidden.
Somebody else might know more about this and chime in.
Old Nov 15, 2019 | 02:57 PM
wendellp601
There is no "reset" for the fuel gauge.
The needle moves according to the variable resistance signal from the sending unit.
If your C3 is 1978 - 1982, the signal wire is pink going into the gauge cluster.
For 1977, this wire is tan.
(I'm not familiar with the wire colors on other years)
Check this wire's continuity between the gauge and the in-tank sending unit.
If the wire is securely attached to the gauge and also the sending unit with good continuity, the sender is bad.
Here's another link to the Willcox site with a video about troubleshooting the fuel gauge.
http://repairs.willcoxcorvette.com/1...el-gauge-test/
Edit: I don't see any wires attached to the sender in the photo you show in post #5.
This wire should run to the driver's side of the tank and into a harness behind the driver side rear wheel.
Also clarified the comment about signal wire color.
Old Nov 15, 2019 | 03:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
If his gauge is still in the cluster, it would be tough to get a jumper lead to it. Got any other ideas to test the circuit? I believe the gauge is ok, but his first post says new sending unit.
Where does the sending unit ground itself?
Old Nov 15, 2019 | 03:23 PM
wendellp601
In the photo in post #5, the ground wire should be attached to the spade terminal at 1 o'clock.
The signal wire attaches to the terminal at 9 o'clock.
Old Nov 15, 2019 | 03:58 PM
CiCiC3's Avatar
CiCiC3
I had disconnected the wires in the photo thinking the fuel gage would go back to zero but apparently not. I'll disconnect the battery now and see what happens. I need to connect an ohm meter and check results but not today it's too cold I'll wait for better weather haha. Thanks for your help!
Old Nov 15, 2019 | 04:16 PM
wendellp601
When you break out the ohmmeter, I suggest starting by checking resistance between the signal terminal and ground terminal on the sender. If the tank is empty, the meter should read zero. If there is any fuel in the tank, the meter should read above zero and up to 90 if the tank is full.
If this test is OK, the problem is in the signal wire.
I've had a flaky connection at the terminal at 9 o'clock before that caused this.
Old Nov 15, 2019 | 04:25 PM
MelWff's Avatar
MelWff
Did you at some point twist the outlet pipe on the sender during removal or installation to cause that contact with the ground tab.
If you did and the pipe can be twisted by hand you broke the solder joint and the sender will leak.
Old Nov 15, 2019 | 06:50 PM
CiCiC3's Avatar
CiCiC3
No I didn't lay a finger on that. Just used a screw driver to push the lock ring off and then on again at install. Did not replace the sending unit.
To gas gage is pegged
Old Nov 15, 2019 | 08:57 PM
CiCiC3's Avatar
CiCiC3
I measured 4K ohms at the sending unit between the ground tab and the signal wire. It supposed to be .4 ohms. May need to recheck with another meter.
Old Nov 15, 2019 | 09:13 PM
TimAT's Avatar
TimAT
A quick and dirty test I used back in my dealer tech days- nobody seems to agree and thinks I'm full of s***, but it works. 12v test light with an 1893 bulb. Disconnect the sender and put the test light from the wire to a ground. Key on, test light will just barely light up, but the indicator will go to about 1/2 tank. Unless the gauge is bad. Works for temp gauge too. When you're working flat rate money, all the quick tricks you can come up with make you more cash......
Old Nov 16, 2019 | 09:07 AM
HeadsU.P.'s Avatar
HeadsU.P.
I'm impressed. Not about the test. But rather, you have a lightbulb 126 yrs old!
(drum / cymbal roll please)
