Adjustable Rear Strut Rods question.
Old Nov 17, 2019 | 12:41 PM
C3TPI's Avatar
C3TPI
Default Adjustable Rear Strut Rods question.
Adjustable rear strut rods came with my Stage 5 suspension package from Ecklers. I believe they are designed to be used with the stock mount. Does anyone know if they will also work with a lowered mount, or does that take a shorter strut rod? Is the difference worth worrying about?
Old Nov 18, 2019 | 12:59 PM
MelWff's Avatar
MelWff
If the lowered mount you are using relocates it by a fraction of an inch the adjustment should be within range..
Old Nov 18, 2019 | 05:01 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
The range of adjustment on all strut rods that I know of is sufficient to handle both stock and relocated mounts. The lowered mount location needs a shorter overall length for the strut when compared to a stock location but the difference isn't huge. Ride height also plays a role in the required length.
Old Nov 19, 2019 | 11:31 AM
C3TPI's Avatar
C3TPI
Thank you both. I am wondering if the lower aftermarket mount is worth the $100 it costs. I'm also thinking that the stock mount could probably be modified to provide a straighter line between the diff and the shock mounts.
To Adjustable Rear Strut Rods question.
