Blown turn signal fuse
Old Nov 26, 2019 | 04:44 PM
89LT1Camaro's Avatar
89LT1Camaro
Default Blown turn signal fuse
Hi all! My 68 C3 keeps blowing the turn signal fuse as soon as you turn on the lever. The hazards work fine so I’m thinking the wiring must be good. Any idea where to look for the turn signals blowing? Thanks guys!!!
Old Nov 26, 2019 | 04:58 PM
MelWff's Avatar
MelWff
Not that this is necessarily related to your case but I had a similar problem and traced it to whenever I put the car in reverse, 4 speed. Discovered the backup switch wiring was touching an exhaust header.
