Getting ready for solid roller cam for SBC 421 build using a Dart SHP block.
I know I need the +.300 high lifters to clear the lifter boses. And they should be installed before putting the heads in place.
Looking at price=quality factor, there is quite a variety in prices. And differences in bearings (roller) vs bushing styles. Prices anywhere from $200 (used Nascar lifters) to $1000 versions.
I see Morel tossed around here a lot.
What is a good recommendation for solid roller lifters with a target of .600 lift on the cam?
I'd like to think under $500 is a good price point.
And where is the best deal available?
Dennis
Dennis, I am using the Morel bushing lifters. Bought them from Chris Straub, as Jackson noted above, for the best price I could find. Obviously no street time yet but the sizing was perfect which I have read is an issue with some of the others. I would definitely suggest buying your lifters before you machine the block so you can dial them in perfectly. Come on over buddy! Let me know if I can help.
Make sure you check the lifter bore size, the shp is known for being machined on the tight side.
Actually Dart states same in there spec sheet along with deck being a little higher than 9.025.
it seems they leave a little extra for final fitting.
I expect more machine work than just boring to 4.155.
Thanks for the info.
They do on their website. I checked that first. I was referring to a comment/post some months back that recommended someone who gave a special forum price.
Thanks.
I'll reach out to Straub.
Thanks Bill.
What you said about getting the lifters first before the machine work, I totally agree.
I'll have everything but the cam before going to the machine shop. Pretty close.
Yeah, I keep thinking of giving you a call to see your beast very soon.
You know what tears up a lifter? High spring pressure and idling.....yep, idling. We knew this over 25 years ago when the first NMCA guys tried driving their cars around.......talk about fail-blog.
Anyway......the best bang for the buck in the lifter world is the Crower. Money no object? Isky Red Zone. There may be others out there......but stay away from the $300 Comp lifters.....
Both Isky and Crower have oiling options too.....and be aware of them when you purchase. We never kept oil option lifters on the shelf....I doubt anyone else does either as they are a custom card and require 4 weeks to build.
Ok I'll be the odd man out and ask the question with .600 lift could you run a hydraulic lifter and not need to worry about periodic checking clearance and adjustment without valve float? I'm by no means a SBC 421 cube expert just asking the question. On my 6.2 LS I'm running .623 lift with 220I-230E 114 CL with stock LS7 lifters. Rev limiter set at a very safe 6500.
I suspect you can rev much higher with a solid lifter but with the 421 cubes and good heads will you really need to?
Again just asking the question.
I agree here......if you buy a premium lifter a modern Hydraulic Roller will go 6500 or better......all a 421 will ever need to rev.
