Engine builders?
Old Dec 12, 2019 | 06:05 PM
gkull's Avatar
gkull
Default Engine builders?
I would like to know what is the best product to use. What I have is a type of crankshaft that the flywheel bolts go into oil. So I needs it to be a sealant and also work like a thread locker like red or blue Loctite.
Old Dec 12, 2019 | 07:01 PM
7t9l82's Avatar
7t9l82
In wondering if a wrap of telfon tape on The one endi of The bolt with a drop of locktite a few threads from The head?
Old Dec 12, 2019 | 07:05 PM
jackson's Avatar
jackson
sealant of your preference in concert with adequate torque and, if feasible, safety wire.
Old Dec 12, 2019 | 08:10 PM
Duke94's Avatar
Duke94
This stuff. Works in oil and a lot of other automotive type fluids.
https://www.mcmaster.com/45855k71
Old Dec 12, 2019 | 08:52 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I was going to mention an anearobic sealer like what I use on the rear main cap to block surface. But I see Duke94 beat me to it with that Loctite 542.
Old Dec 12, 2019 | 10:19 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Loctite 592 is what I would use. It is automotive high temp designed for oil fittings and automotive fluids.
Old Dec 13, 2019 | 08:08 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
We used Loctite 620 at World products years ago to install tubes into BBC Merlin heads on the 345's when the head bolt broke into the intake port due to core shift. No issues. It is "Green Machinists Loctite".
The 592 is good product but has little "hold" value.
Is the crank flange thick enough to use a set screw to plug it up?
Jebby
Old Dec 13, 2019 | 10:59 AM
gkull's Avatar
gkull
I've thought about the dual idea.
This is what I decided to order
Amazon Amazon
Jebby
I also thought about safety wire, but the owner said NO. I will look into allen plugs and shorter bolts it would fix the crank for life.
This all started when I took 5 of my car guy buddies to Ford VS Ferrari. We went to a plush Imax super HD theater with reserved seating. Hardly anybody was there on opening day in the early afternoon, but a couple sat in front of us and the guy had a removable Ford GT steering wheel in his hands. So we got to talking and he had driven his racing GT40 to the movie with Avon grooved slicks on it. I told him that I used to work on the real ones at a historic race shop. So his replica has a 338 ci stroker 13.2 c/r 550 hp motor. It had developed a leak in the flywheel area. So I offered to work on it. It is some kind of a Flat plane crank with a 12 inch tiny flywheel and a multi disk clutch setup going to the 5 speed transaxle. He is a historic event national winner in his other car and trying to get this sorted out for 2020 racing.
Old Dec 15, 2019 | 09:10 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Let us know if it works, because I have a problem with the #5 intake manifold bolts leaking oil. Thanks T
Old Dec 15, 2019 | 03:36 PM
gkull's Avatar
gkull
This is what I have used for many years on intake and head studs into oil or water.
Amazon Amazon
Old Dec 15, 2019 | 05:12 PM
71 Vert LS1's Avatar
71 Vert LS1
Maybe not right for your application but on my LS engines, the crank bolt holes are open to the block I've just used Loctite blue medium strength. Never had a leak.
Old Jan 7, 2020 | 03:03 PM
terrys6t8roadster
https://www.amazon.com/Permatex-8006...59NEA9PTD8PBJ6
What color is the permatex you recommended? Purple? T
Old Jan 7, 2020 | 03:50 PM
gkull's Avatar
gkull
It's kinda reddish purple. I been using it on other things like screw in studs and intake bolts
Old Jan 7, 2020 | 04:51 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
We used that in the late 60's on everything.
Just about the only thing you saw in the gas station garage or the 2 car dealerships I worked in.
Long before RTV sealant in the tube and threadlocker in the bottle.
Some things don't need improvement....
Old Jan 8, 2020 | 05:07 AM
terrys6t8roadster
Thank guys, I have some of that stuff left from the forkjeep days but packaged under different labels. T
To Engine builders?
