Short Block Build
Which would you suggest somewhere in the middle $$. Tks
https://www.summitracing.com/int/sea...d=1.6%20rocker
Sometimes lack of research on your part causes the rocker to strike the valvespring retainer. But that's rare.
Sometimes the extra ratio can cause spring bind. But that's rare also.
The cam you selected is mild enough that the two above issues should be of no concern. However, I would rather not recommend rockers or cam brands.
I 'm usually not a big fan of altered rocker ratios that make-up for lost lift from a incorrect cam. Its always better to order the correct dur / lift / LSA.
But in your case where a "top-end" kit has already been ordered, then by all means, get the 1.6s. The more I read on that kit, the better it looks. And you can trust Edelbrock has tested that combo a billzillion times with good results. And I believe those horsepower numbers are not exaggerated. Makes a nice street cruiser.
The pushrod moves closer toward the stud when the ratio is increased, unless the head was already machined for this clearance by the mfgr. "Better safe than sorry".
I think the 1.6's are a great recommendation with this cam, but only on the intake side, and it should equal 219* / .496" @ the intake valve w/1.6 on it. I'm sure the head passes more cfm @ .496" than .464" lift.
If you use a 1.6 on the exhaust also you may very well loose power over the original 1.5/ 1.5's !
And I would ask edelbrock if the added ratio would require a slight shim for the intake side to increase spring rate, and whether or not they tested with 1.6's also.
$.02
I will admit, I sat in the back of math class and nodded off on occasion. But this is how I came up with valve lift on the Exh side.
First I find the lobe lift by taking their data of .470" lift on the exhaust and dividing by the std rocker ratio of 1.5.
This establishes the cam lobe is 313.33".
Then I multiply that figure by the new rocker ratio of 1.6.
It came out to: 501.28 lift.
The reason the exhaust duration & lift is favored more than the intake is, that its been said that Chevys are terrible at exhausting gases. They have been that way for decades. This is regardless of what type of exhaust system is incorporated. But long tube headers helped.
So over the years, as the story goes, old Chevys ran better with dual pattern camshafts. Hold that Exh valve open a little longer. Maybe so, maybe not.
$.02
I'll let you guy's know what Edlebrock says in regards to the increased Rocker ratio shimming on the intake side & testing of this. Hopefully they did, and have an answer.
Tks,
Myles
If you only have 1.5 run them, if you want more and score the 1.6 you can. Dont think it will make a big difference
You can run roller tips too and fit under the valve cover no need for full rockers. 1600 is cheap for what you get.
This altered ratio concept brings up another point:
I am not an expert on Eddy heads, but normally when "Guide Plates" are involved and I repeat, normally, the pushrod slot is rounded out for pushrod clearance instead of oblong. If this is the case on those Eddy heads which HAVE the guide plates, then the 1.6 rockers will work fine w/o the pushrods rubbing the head.
How much more H.P. between 1.5 and the 1.6 rockers?
Easy, non debatable, hands-down, correct answer is:
Between 1 & 1,000
IMFB, routine blasts to 6K+ are just that; routine
Now that ya know how to back-calculate RAR & valve lift increase w/ 1.6:1 RAR ... perhaps ya can do likewise with duration @ 0.050" LL ?
https://www.edelbrock.com/e-street-t...hevy-2038.html
But I'm not getting into all that. Its not that important here.
Here is Edlebrocks response to a shim on the intake side of the Heads in the 2038 kit.
Your Product Question:
Hi: Do you know if the heads in the 2038 Top end kit have been tested with 1.6 Ration Rocker Arms ? If so would the added ratio from 1.5 to 1.6 require a slight shim for the intake side to increase spring rate.
Tks Myles
Answer:
Myles, Yes you can use 1.6 ratio rocker arms on the Edelbrock E-Street cylinder heads, and you do not need to add any shims at all, no need to increase the spring pressures for using 1.6 ratio rocker arms, not sure why you want to use 1.6 ratio rocker arms, for no gain in performance....
Edelbrock - January 9, 2020
Myles
I beg to differ, but I want David Freiburger standing next to me at the dyno.
I know those ads in performance catalogs claiming 20-25 horse gains by using their 1.6 roller tip rockers, is ridiculous.
However:
Anytime a Intake Valve is held open a little longer or opened a little bigger, that's just that much more CFM to enter the cylinder, more mixture to be compressed, which equals more power. But, whatever. He's the tech guy.
I still think the correct statement from him should have been a modest gain depending on application.
And NO OTHER MODS. Most of those dyno test videos I have seen on YouTube include more than one alteration. Such as: after changing rocker ratio + a bigger carb, + more timing, bigger header tubes, etc. (Not a fair test assumption)
