Fuel Pump.
Old Jan 8, 2020 | 06:28 PM
grumpy73's Avatar
grumpy73
Default Fuel Pump.
I have a 355 Crate with a Quick fuel 650 in my 73. The fuel pump went south and I replaced it with a holly electric. Due to the noise I have decided to go back to a manual and need a recommendation on a fuel pump. Will a stock pump have the gph to do the job.
Old Jan 8, 2020 | 06:53 PM
MelWff's Avatar
MelWff
Use a Holley mechanical street pump
Old Jan 8, 2020 | 07:38 PM
OldCarBum's Avatar
OldCarBum
It will depend on your engines demand for fuel and how you are using your car.
You don't want it to starve for fuel when you nail the throttle.
You should also run a good regulator set for your Quick Fuel carb.
My Quick Fuel regulator is set for 7psi per their recommendations.
Call Holley tech services and get their recommendation for the pump.
Old Jan 8, 2020 | 10:23 PM
jackson's Avatar
jackson
Yes ... replacement ACDelco
Old Jan 9, 2020 | 06:27 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I havent broke my edelbrock, but I did brake alot of the carter stock units
Old Jan 9, 2020 | 01:49 PM
BKbroiler's Avatar
BKbroiler
This is the best choice. I have an AC Delco stock replacement pump (dirt cheap from rockauto.com) on my 383. I've gone 12.15 at 110 mph with it. No problems.
To Fuel Pump.
