1980 cluster illumination not working
Old Jan 17, 2020 | 08:30 AM
Rubicon383's Avatar
Rubicon383
2nd Gear
Default 1980 cluster illumination not working
Hello,
I’ve used this forum for years and it has been an asset, I greatly appreciate all of the knowledge offered by all of you.
Unfortunately, I have been unable to find much about the current problem I have, so I made an account to ask.
The illumination lights in my tach/speedo cluster do not work. They have before, but suddenly went out. The turn signal indicators still work, high beam, etc. only the illumination is out, but the illumination lights in the center console gauge cluster works, which is why I’m at a loss.
Any help would be greatly appreciated.
Thanks!
Old Jan 17, 2020 | 08:38 AM
VirginiaVette78's Avatar
VirginiaVette78
I am going through this same issue right now on my '78. From my research, you need to check the rheostat inside of the headlight switch. The switch itself is pretty cheap to replace, i just bought one yesterday from Willcox for like $30. Looks easy enough to change out. This is all assuming you already checked out your fuse as well. If fuse is good, most of the time its the headlight switch with a bad rheostat.
Old Jan 17, 2020 | 08:39 AM
VirginiaVette78
https://willcoxcorvette.com/corvette...p-switch-78-82
This is the one I ordered yesterday. Same one for you
Old Jan 17, 2020 | 08:49 AM
Rubicon383's Avatar
Rubicon383
2nd Gear
The rheostat dims the lights smoothly in the center cluster, so I ruled it out. But as stated it is fairly cheap to replace. I’ll swing by my local parts store and pick one up.
Old Jan 17, 2020 | 05:15 PM
TedH's Avatar
TedH
Next step may be to remove the speedo/tach cluster and check the bulbs. I replaced mine years ago and never another problem. I went ahead and replaced the bulbs in the center cluster while I was at it and even replaced the bulb that fires down onto the shifter/ashtray for good measure.
Old Nov 12, 2023 | 09:26 AM
deli-man's Avatar
deli-man
4th Gear
I have the same problem, but its the center cluster which will not illuminate and the dash (speedo and tack} lights work
Old Nov 15, 2023 | 01:49 PM
RubyRedMetallic's Avatar
RubyRedMetallic
Mine did that. It was the power plug on the bottom of the speedo cluster that came unplugged. Right at the bottom below bulbs, black plug , energizes entire metal gauge back makes lights on both light up. Headlight switch us a likely culprit too.
Old Nov 16, 2023 | 11:15 AM
JavaJolt78's Avatar
JavaJolt78
VV78...........
I also have a 78 that has an illumination issue..I could not open the Willcox link???
Are there other sources for the switch and rheostat??
JJ78
To 1980 cluster illumination not working
