Quick strut rod question
Old Jan 19, 2020 | 08:05 PM
Barrist's Avatar
Barrist
Default Quick strut rod question
Is it necessary to remove the rear spring, to R&R strut Rods ? Trailing Arms were done before purchase, so I trying do do this the "easy" way, if possible.
Thanks, and have a Great Day,
Bill
Old Jan 19, 2020 | 08:13 PM
Mooser's Avatar
Mooser
No. I don't think so, it's kind of in the way a bit but it's not connected to anything you need to remove to get at the strut rods
M
Old Jan 19, 2020 | 08:25 PM
BLUE1972's Avatar
BLUE1972
No,
The strut rods can be removed without removing the spring. The lower shock attachment must be removed.
The strut rods can be removed, easily. I jack up the car and remove the tires, it just makes it easier to remove the shock mount.
You will need an extra nut to drive the lower shock mount out. Thread it on to protect the threads. You hit on the nut to remove the shock mount.
If you still have the camber adjusters on the struts inside mounting bolts - mark them to put the setting back as it was.
To Quick strut rod question
