Headlights
Old Jan 21, 2020 | 03:24 PM
Chksbak's Avatar
Chksbak
8th Gear
Default Headlights
I know the headlights on my 79 don't work correctly. Is there a tool to use on the system to create vacuum , so I can trouble shoot the system with out needing to have the engine running.
any good headlight advice?
Old Jan 21, 2020 | 03:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My-T-Vac
Old Jan 21, 2020 | 04:03 PM
L-46man's Avatar
L-46man
there is also a vacuum inducer available through HFT that runs off of your compressor....like $17.00
https://www.harborfreight.com/air-va...ors-96677.html
unkahal
Old Jan 21, 2020 | 05:13 PM
BKarol's Avatar
BKarol
Old Jan 21, 2020 | 10:49 PM
brassplyer's Avatar
brassplyer
My-T-Vac
Is the MyTVac any better than a Harbor Freight hand vac pump?
Old Jan 22, 2020 | 09:42 AM
L-46man's Avatar
L-46man
They are two different animals...I have both.
My-T-vac is a hand pump....if you are troubleshooting an individual component....pretty good unit....you have to squeeze the pump a bunch of times to get the vacuum you want.
When you are trying to troubleshoot a whole system...the HFT pump is better.....your hands could break off if you have a leak in the system.
The HFT pump will pull 28" of vacuum continually at 125 psi on your compressor.
HFT is also great for evacuating the A/C system to remove moisture....for an HOUR.....your hands would be dead by then, with a My-T-Vac.
Buy BOTH!
Unkahal
To Headlights
