need help with diff snubber
Old Jan 22, 2020 | 09:49 PM
HELOPILOT14Y's Avatar
HELOPILOT14Y
7th Gear
Default need help with diff snubber
I just removed my well worn out differential snubber. I watched all the videos and thought it would be easy. Now I'm having trouble putting in the new one. The new bottom one just won't fit in. I tried removing the front horizontal bolt on the bracket. Now I could pull down on the bracket enough to get the bushing in. I got the whole thing assembled, but now I can't get the horizontal bracket bolt back in. Any ideas?
Old Jan 22, 2020 | 10:17 PM
jeffwebley's Avatar
jeffwebley
When I replaced my snubber rubbers, I used a pry bar and a block of wood to force the bracket/diff to rotate down and slipped in the rubber. I cut a notch in the wood to clear the brake line.
Be careful of the brake line that is routed along the crossmember.
Good luck.
Jeff
Old Jan 23, 2020 | 11:54 AM
caskiguy's Avatar
caskiguy
[QUOTE=HELOPILOT14Y;1600841164]I just removed my well worn out differential snubber. I watched all the videos and thought it would be easy. Now I'm having trouble putting in the new one. The new bottom one just won't fit in. I tried removing the front horizontal bolt on the bracket. Now I could pull down on the bracket enough to get the bushing in. I got the whole thing assembled, but now I can't get the horizontal bracket bolt back in. Any ideas?[/QUOTE
Old Jan 23, 2020 | 11:56 AM
caskiguy's Avatar
caskiguy
http://repairs.willcoxcorvette.com/1...-instructions/
Old Jan 23, 2020 | 03:09 PM
mysixtynine's Avatar
mysixtynine
Your probably gona have to take the lower bushing back out again.... your dealing with the suspension / spring torquing on the diff and miss aligning the bolt hole in the diff/snubber bracket..
Put that bolt back in the diff / snubber bracket and then you need to pry down on the snubber bracket itself as described above to slip the new bushing in there.
Old Jan 23, 2020 | 09:26 PM
HELOPILOT14Y
7th Gear
OK I got it done. I did put the bolt back and used a pry bar to pull the bracket down.
Old Jan 23, 2020 | 09:56 PM
caskiguy's Avatar
caskiguy
Atta boy !
To need help with diff snubber
