Body higher on one side
Old Jan 24, 2020 | 10:32 PM
7D3VETT's Avatar
7D3VETT
Cruising
Default Body higher on one side
I have a 73 vett. It’s higher on the passenger side front and back. A inch in the front and inch and a half in the back.
I replaced the mono spring in the back, still off. I replaced the front shocks and springs and still off.
The frame measurement to the ground is close to the same front and back.
could the body to frame be off?
I know about longer bolts for lowering the mono spring but any lower would be to close to the big tires on the back.
Im not sure where the body sits on the frame.
Old Jan 24, 2020 | 10:50 PM
Duane4238's Avatar
Duane4238
From your information, logic tells me that your body is off on that side if the frame is equidistant from the ground. Is the frame the same distance from the ground all the way around? If it is, sounds like you might need some new body mounts or possibly you have some rust issues with the frame at those body mount areas.
Duane
Old Jan 24, 2020 | 11:18 PM
7D3VETT's Avatar
7D3VETT
Cruising
I’m not sure where the body mounts are.
behind the rocker panels?
Old Jan 24, 2020 | 11:28 PM
7D3VETT's Avatar
7D3VETT
Cruising
I just watched a YouTube video on the body mounts . I’ll have a look at them.
Old Jan 25, 2020 | 08:56 AM
Tampa Jerry's Avatar
Tampa Jerry
It sounds like the front springs were not indexed when installed. The top of the spring must be set and indexed in the frame pocket so the end of the spring is just visible in the inspection hole. The AIM says to position it to within 3/8". I use blue tape so I can see the end of the spring easily. Some mistakenly think you should index the spring in the lower control arm. Hope this helps. Jerry
Old Jan 25, 2020 | 12:00 PM
7D3VETT's Avatar
7D3VETT
Cruising
Default Springs
It was off before the new ones were put in.
Les schuab installed them, I hope they knew what they were doing.
I’ll look at their work.
thanks for the input
To Body higher on one side
