81 Electrical Issues
Old Jan 25, 2020 | 10:45 PM
nspctr01's Avatar
nspctr01
Default 81 Electrical Issues
I've got a 81 that I bought not running, Ive put most of it back together and it has a new motor, HEI etc. Doing away with the ECM. I have never had this car running just FYI. So I installed a new ignition switch, jumped the neutral safety switch and when I went to crank it over the motor bumped then blew the fusible link at the starter. Is there a certain place I should start looking? Certain color wires or do I need to take the harness apart and look. I have the steering column dropped, gauge cluster out for access.
Old Jan 25, 2020 | 10:54 PM
MelWff's Avatar
MelWff
Have you bench tested the starter?
Can you provide some more detail on the new engine, used engine, crate engine, etc.?
Old Jan 26, 2020 | 11:40 AM
nspctr01's Avatar
nspctr01
the starter is new as well as the starter harness and the motor will crank if jumped with solenoid wire. Motor is not stock but a bored out 350 hence the HEI.
To 81 Electrical Issues
