Deck lid Spring Tower Removal Question
Old Jan 26, 2020 | 12:58 AM
Sammy T's Avatar
Sammy T
Default Deck lid Spring Tower Removal Question
Is it necessary to remove the spring from the tower prior to removing the tower from the car to gain access to #4 mount for repair? I’d rather leave it as an assembly if possible.
Old Jan 26, 2020 | 05:37 PM
Sammy T's Avatar
Sammy T
Anyone?
Old Jan 26, 2020 | 06:22 PM
twinpack's Avatar
twinpack
Originally Posted by Sammy T
Anyone?
yes. If you need to replace the captive nut. Remove the spring, drill out the rivets, remove the tower and old captive nut. Reverse procedure. I used pop rivits. I have an extra captive nut if needed. You should replace the mou t at this time.
To Deck lid Spring Tower Removal Question
