427 Head Gasket
Old Jan 29, 2020 | 03:32 PM
Steve 427's Avatar
Steve 427
Default 427 Head Gasket
Just wondering what brand/type you guys are using for the head gaskets ? I see some of these replacement ones have different water passages that require drilling the block which I don't want to do.
Old Jan 29, 2020 | 05:29 PM
forman's Avatar
forman
felpro 1045 check the bore when ordering
Old Jan 29, 2020 | 07:04 PM
Steve 427's Avatar
Steve 427
The ones you are referring to 1045 are for a small block Chevy not a big block Chevy .
also there are issues with some of the gaskets and cooling passages for the big blocks that I hear people might not be aware of and cause overheating .
Old Jan 29, 2020 | 07:38 PM
76strokervette's Avatar
76strokervette
Felpro 1027
Old Jan 29, 2020 | 07:41 PM
forman's Avatar
forman
Im sorry we just put some heads on my buddys small block last month ,,go on summit and look them up ,when I did my 454 we used 1027 felpro check the bore size
Old Jan 29, 2020 | 08:20 PM
Steve 427's Avatar
Steve 427
The 1027 Fel Pro gaskets are only for aluminum heads. I have a L71 with iron heads.
I am asking on this thread as I hear there are some gaskets that are for parallel flow and some for series flow cooling passages.
Wondering what people have actually used without drilling out their blocks.
Old Jan 29, 2020 | 08:26 PM
76strokervette
Old Jan 29, 2020 | 08:29 PM
forman's Avatar
forman
Pm jebby he’s good with this stuff
Old Jan 29, 2020 | 09:07 PM
76strokervette
Cometic C5329-40 if you are not budget shopping.
Old Jan 29, 2020 | 09:08 PM
jackson's Avatar
jackson
Which heads?
What year is your block?
What does bore measure?
How thick do you require?
Old Jan 29, 2020 | 09:12 PM
Steve 427's Avatar
Steve 427
Originally Posted by jackson
Which heads?
rect port iron heads
4.280 bore
.039 thick + or -
1969 block
1969 427/435 L71 to be exact
Old Jan 29, 2020 | 10:32 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Sounds like your engine might be all original. If you are to ever have your car judged I believe you need Black and or Grey head Gaskets and You will get a deduction for Blue ones.
Old Jan 29, 2020 | 10:45 PM
jackson's Avatar
jackson
4.280 bore
.039 thick + or -
1969 block
Originally Posted by 76strokervette
1017-1
FP 1017-1 is only one of a dozen or so that does Not say "pre-1971 blocks may require modifications" ... exception is 1027 ... says it doesn't cause brinnel in aluminum but why not for cast iron?
Those are felpro Performance
below is felpro OE replacement type ... that'd be my pick ... unless you really Need something more
head gasket 8180 PT-2 ... $19 each at summit ... versus $45 each for the 1071-1
https://www.fme-cat.com/overlays/par...0CORVETTE&vin=
for reference ... OE replacement full gasket set for rectangle port 427 is sealed power 260-1081 or felpro 2601081 ... price diff! g'luck!
Old Jan 30, 2020 | 08:57 AM
Steve 427's Avatar
Steve 427
Yes all original. Still has the TRW 3888304 pistons in it.
Old Jan 30, 2020 | 09:06 AM
jackson's Avatar
jackson
Sorry, I'm the wrong guy for NCRS-approved part numbers for internal engine parts.
Maybe you visit local GM dealer & x-reference to GM numbers. Or. Krylon, Sharpie.
Old Jan 30, 2020 | 09:10 AM
Steve 427's Avatar
Steve 427
You are fine I just want a good product that will work. Little paint on the edges will do the trick
Old Feb 2, 2020 | 12:26 PM
bence13_33's Avatar
bence13_33
How far down in the bore is the piston? If it is all original (the block hasn't been decked), typically the piston is like .020" down in the bore. Optimal quench for an engine is usually around .040", have you considered running a .020" steel shim gasket? That would get you to .040" quench and it would also pick you up a little bit of compression if you were running a .040" gasket. You would obviously want to check piston/valve clearance on this if you decide to try that. Just an idea.
Old Feb 2, 2020 | 02:01 PM
Crimson Thunder's Avatar
Crimson Thunder
If he has an original L-71, I doubt he wants MORE compression.
To 427 Head Gasket
