cold starting or not . . .
Old Nov 19, 2002 | 09:54 AM
davs79's Avatar
davs79
Default cold starting or not . . .
i've noticed over the last month or so that my 79 is getting harder to start. each time it seem to get harder to. the battery is good cause it will crank over the car all day long to the point of it becoming flooded. the chock seems to be working correctly. it acts like its not firing. any tip on checking if its firing or not? any suggestions?
:chevy
Old Nov 19, 2002 | 10:11 AM
BB68Vett's Avatar
BB68Vett
Default Re: cold starting or not . . . (davs79)
I like to hook up a timing light to a spark plug wire and then crank the car and look for the blinking light on the timing gun. No blink, no spark.
Old Nov 20, 2002 | 08:42 AM
davs79's Avatar
davs79
have no spark (or blinky light), replace the coil?
:chevy
Old Nov 20, 2002 | 08:51 AM
81Vette_by_eric's Avatar
81Vette_by_eric
I'm not sure what to replace. But you are scaring me with the no start talk :cry
Good luck to you.
Old Dec 1, 2002 | 03:45 PM
The Money Pit's Avatar
The Money Pit
If there's no spark check the distributer power to see if you have your 12V feed. If not check out the ignition switch,if you do,check into the module in the distributer,the coil or cap. I had a cap where the center electrode was almost completely gone,and the SOB still started and ran.
Old Dec 1, 2002 | 07:52 PM
woodsman's Avatar
woodsman
:iagree: I think The Money Pit has identified the area. My mom had an 82 Buick with highway speed skip and I went through everything until I discovered that even though the +12V connector to the HEI distributor had power, the copper connector was so dull and surface corroded that it wasn't making good contact. Try unplugging it and scratching up the surface of connector and recepticle contacts. It solved the problem on the Buick for several years then I had to do it again. A little oil/grease on the contacts after cleaning seems to extend the useable time.
To cold starting or not . . .
