1969 C3 Lights Work, Won't Crank
Old Feb 12, 2020 | 07:55 PM
HeadsU.P.'s Avatar
HeadsU.P.
Overly rich mixture is black smoke.
White Smoke could be coolant! Lets hope that's not what you're seeing.
And for what its worth, old engine exhaust w/o cats and smog crap just stink. That's just the way it is, especially with any modest cam upgrades, carbs, etc. We get spoiled with modern exhaust systems.
Old Feb 12, 2020 | 08:22 PM
Bikespace's Avatar
Bikespace
Do yourself a favor and get a boot. If you drop a screwdriver between that oversized washer, or just the nut, and the body of the car, you can burn up a wire, or even burn up the car.
What diagnostic tools do you have at your disposal? Ignition issues are easiest to diagnose, if you have a timing light. Vacuum issues are also easy, if you have a vacuum pump and a pack of vacuum caps (Amazon or your local auto store). It may well be a carb issue, but if it were my car, I'd want to eliminate all of the easy problems first.
Old Feb 25, 2020 | 04:21 PM
BlankSlate's Avatar
BlankSlate
I want to thank everybody for their input on this! For now, the problem seemed solved! Could not have done it without you!
