79 steering column shroud
Old Feb 5, 2020 | 05:26 AM
stilltrying's Avatar
stilltrying
Default 79 steering column shroud
I broke the cast ali mount for the indicator/high beam switch in my tilt and slide column. How do I remove the lower plastic shroud/cover that is below the tilt lever, without breaking it. If I can get this off it looks like I will be able to drift out the pin holding the rest of the broken piece in place.
The column is out of the car.
