C3 Brake Cooling Options
Any suggestions? Thanks in advance...
Joe
http://www.tirerack.com/brakes/tech101.html
Just be cautious, I don't think that the article goes into it, but some pads that are "fade-resistant" may not be appropriate for street use because they don't become effective until they get hot.
There are always larger rotors, six-piston calipers, and such, but the pads may be a good starting point (if you haven't already experimented with different ones).
I am now using competition brake pads. They are not too bad when cold, and improve when hot. I did in fact have much worse brake fade problems on the original soft compound pads, so I converted the car to power brakes to use and compensate for the competition pads.
Of course, as the lap times get better, the brakes are working harder :) especially with the extra grip of the Hoosier slicks. So I was hoping to duct some more air to the discs, to avoid major brake upgrade, and thought there might be a kit to do that.
Thanks for your help. Perhaps others might have some suggestions for me as well.
Joe
will_shepherd@hotmail.com
you cant mix it with anything except dot 5 and it is much more expensive. The only other thing to watch out for with the dot5 is that it isnt hydroscopic so it will not absorbe moisture. Any moisture in the system will generally sit at the lowest points and start rusting parts. This isnt a problem as long as you change you brake fluid on a regular basis.
Kevin
These worked for me
the other mods that i feel are invaluable if your going to do alot of speed events in a c-3 are 1) brake fluid [i'm running blue oval d.o.t. 3] 2) pads, i'm using over the counter performance frictions i got from autozone for $35 with a lifetime warranty. they're not the best i could run but beat the hell out of the factory organics. 3) russell steel braided teflon lined brake lines. 4) a proportioning valve. i think this is the single biggest improvement you can make of all of them. the reason is that the weight transfer and rear spring have a tendancy to jack the back of the car up during heavy braking causing the load the rear tires see to lighten significantly. obviously, the rear tires then want to lock up and the supercomputer behind the steering wheel determines too much braking and eases back on the pedal, thereby increasing the stopping distance. installing an adjustable proportioning valve on the rear allow you to reduce the brake bias to the rear so that the fronts lock up just before the rear. it will take a few times of romping on the brakes to get the bias figured out but once you get it set up, you will be able to brake deeper and harder into your turns.
P.S. keep a close eye on the rotors. They WILL overheat and you need to watch for cracking and grooving on a stock system. Larger drilled and grooved rotors, and better calipers are probably the single best thing you can do to improve lap times.
Hans
[Modified by Wrencher, 11:50 AM 11/20/2002]
Flynhi,
Thanks for the offer, shipping to Oz will be a killer, do you have any photos of the spoiler? perhaps I could fabricate something similar here.
Aharte,
I followed up on that thread, and Clutchdust has also replied. Some good ideas there.
Kevin,
To use DOT5 I assume you have to dismantle and completely clean all of the braking components to eliminate older brake fluids.
Joni,
Thanks for the tip re backing plates. Do the rear brakes overheat or is it just the fronts?
Clutchdust,
Thanks for the ideas, I think I can make that work. My brakes seem to be well balanced....front's locking up just before rears, so I'll leave proportioning valve till later. Did you remove backing plates on front? Where did you aim the air from the duct? Sounds like you taped it to the lower bump stop and pointed it into the area between the rim and backing plate? Did you have overheating problems before or was this a precaution? Did you have any overheating problems on rear brakes.
Wrencher,
Thanks for the tip and warning. Seems there's always something else to consider, when you improve something, you can go that bit faster & stop that bit better, it will often take something else past its design limits.
Best regards,
Joe
Glad to help .As for rear brake overheat ,i have no recorded data to back it up but C3 whellwells arent wery open, so i thought extra cooling wont hurt and keeps rotors safe.
Kevin
1-coefficent of friction is a function of temp, and is inversely proportional
2-high temps can boil brake fluid, resulting in fluid compression
To control temps
-use high-performance pads with a more constant and greater friction coefficient. combine with a rotor of quality material and proper surface finish.
-larger rotors for a) more mass for more heat absorption, increased convection surface area for cooling b) more mechanical leverage for increased stopping power, resulting in more cool-down time in the cycle
-ducting, vented rotors, open wheels
-reduce the weight of your car... :p:
What about applying some conducting paste between the rotor and spindle face? this would effectively increase the mass of the rotor, allowing heat to move to the spindle much more easily than if were just metal-metal contact. might cause bearing clearance problems if heat it too much though...
[Modified by Turbo-Jet, 11:42 PM 11/20/2002]
washingtonracer, i'd think the c-4 master cylinder wouldn't push as much fluid as the original. remember some early c-4s had single piston calipers and even the dual piston calipers likely didn't require as much fluid as our four piston calipers do to apply sufficient clamping force. you should really talk to some place like VBP or wilwood to get a fair comparison.
