Dumb question on the nite---insulation question
Old Nov 19, 2002 | 08:19 PM
7tea1's Avatar
7tea1
Default Dumb question on the nite---insulation question
OK- I feel stupid but....I'd rather do it right the first time. I bought a roll of foil backed carpet insulation at Peppy Boys.
When replacing carpet, does the foil face the carpet, or does the foil face the floor board???
I warned you it was a dumb question. :crazy:
Old Nov 19, 2002 | 08:21 PM
BeachinVette's Avatar
BeachinVette
Default Re: Dumb question on the nite---insulation question (7tea1)
I think the foil will face the floor board. not a 100% but pretty sure.
Bob
Old Nov 19, 2002 | 08:50 PM
Neil350's Avatar
Neil350
St. Jude Donor '12
yea, foil goes down.
Old Nov 19, 2002 | 09:00 PM
vettfixr's Avatar
vettfixr
The foil should go down if there's foil on only one side of the insulation. I used insulation with foil on both sides so it didn't make a difference. Where two pieces join together use aluminum duct tape to seal them together so you end up with one continuous piece of insulation. This prevents heat from leaking past the joints and holds all the pieces together better. Here's a pic
Old Nov 19, 2002 | 10:53 PM
7tea1's Avatar
7tea1
Default Re: Dumb question on the nite---insulation question (vettfixr)
Vettfixr- VERY, VERY impressive!!! Looks like 1 piece!!
Thanks guys for the replies
Old Nov 20, 2002 | 05:55 PM
Woodstoc's Avatar
Woodstoc
Kinda look at it like this, you want the heat to reflect away, or soak into the insulation? Reflect is the best choice.
To Dumb question on the nite---insulation question
