Front Hub Assembly
Old Feb 14, 2020 | 03:15 PM
C3TPI's Avatar
C3TPI
Default Front Hub Assembly
When replacing the front rotors, is it necessary to re-rivet them to the hubs or will the lug studs hold them in place sufficiently?
Old Feb 14, 2020 | 03:17 PM
kkerley's Avatar
kkerley
lug nuts should be sufficient
Old Feb 14, 2020 | 03:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Index the rotors to a lug before you remove the rivets. The rivets where for runout machining purposes. If you don't index them, you could have runout issues.
Old Feb 14, 2020 | 04:29 PM
SH-60B's Avatar
SH-60B
No point in indexing, he's replacing the rotors.
The lug nuts will hold fine, but they may need to be shimmed to get acceptable run-out.
Old Feb 14, 2020 | 10:06 PM
C3_DH's Avatar
C3_DH
On my recent brake job, I tried to drill out those rivets very unsuccessfully. I had new rotors so I finally ordered new hubs - and was told, after doing some research, that no, you just put the rotors on the hubs, and the wheel/lugs keep them flush for the calipers and pads.
Old Feb 15, 2020 | 08:03 AM
C3TPI's Avatar
C3TPI
Thanks everyone, kind of what I thought. I have shim material if needed. I will measure run out with a dial indicator like the book shows.
Old Feb 15, 2020 | 09:16 AM
GTR1999's Avatar
GTR1999
This is how I do them, works great but your choice
https://www.digitalcorvettes.com/thr...dial-in.77063/
Old Feb 15, 2020 | 09:46 AM
kkerley's Avatar
kkerley
great information GTR1999, do you have a picture showing what your shims would look like if needed to correct the runout and how you place them?
To Front Hub Assembly
