engine rebuild recomendations
The following applies if you Are reusing/rebuilding OE Iron heads
Unless you Have to, don't deck block.
Do ensure the rebuilder uses pistons with compression height = 1.560" (stock height)... This will put pistons 0.025" Below stock deck ... Don't use the shorter budget rebuilder pistons ...
Have the rebuilder check the heads for straightness and, if Needed, have the heads surfaced. Each 0.006" milled from head Reduces chamber by approx One cc.
Do ensure rebuilder uses a thin shim (0.015") head gasket e.g. Fel-Pro 7733 SH-1
*stock uncut deck with 1.560" pistons with 0.015" gasket yields Ideal Quench of approx 0.040"
Or just take a pic of them, theres your proof. If that isnt good enough for some guy down the road he didnt want it in the first place?
Deck it and do things right. They are usually off from the factory plus 50 yrs of heat cycling
I read some crap on Skip Whites ad for his engines that say it compromises deck strength.....bullshit. He just doesn't want to spend the extra labor to make more passes on the cutter.
Anyway.......there are just SO many ways to go.......too many to list......
The biggest question right now are:
How much power do you want? (Do you think a 13-14 second car is fast? Is that good enough?)
Are you keeping the stock hood?
What is your budget?
Jebby
Jebby
That extra machinery fees could be better spent elsewhere. But its not my money, not my business. Just saying that block milling, align boring, etc is all "Blue Print" strategy. And I don't believe that's the road you are intending to go down.
Jebby
So, since a quarter-century experience seems important ... I've been doing this for a while as well ...
... from some of your post's age disclosures, it seems more than a few of us here belong to your late father's generation.
So, in addition to sob, just call me old sob / old fencepost.
FWIW, the OP writes he's 'not after max power & just wants to help it a little.'
I've observed many such milder motor expectations here ,,, quite often they're met here with performance suggestions far in excess of OP's stated goals.
It's all too easy to spend another's money.
I'm using the stock exhaust manifolds as well so I can only help it so much. I'm just a cruiser so not worried about 1/4 mile stats.
The roller cam swap is desirable for a number of valid reasons but the cost is rather high. Flat tappets can get this job done with much more modest parts. Just a money call for you to make there.
My opinion is leave the deck alone unless you can see surface damage or warpage with a feeler gauge and a straight edge. Same with the heads surface. I would need to see more than .004" warp across the heads before considering a cut.
So if/once you have some specific questions on parts we could be more helpful.
Good luck.
