76 Front Suspension Rebuild
Old Feb 15, 2020 | 10:16 AM
ykf7b0's Avatar
ykf7b0
Default 76 Front Suspension Rebuild
I'm planning a total rebuild of my 76 front suspension when the weather breaks and I want to read suggestions on where to buy and which bushing type please. Any tips on installation are greatly appreciated!!!
Old Feb 15, 2020 | 11:26 AM
gjohnson's Avatar
gjohnson
Use rubber bushings not poly
Old Feb 15, 2020 | 11:34 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
If you don't want a performance upgrade go with stock style rubber
Old Feb 15, 2020 | 08:47 PM
Lobzila's Avatar
Lobzila
I just switched my 68 over to Van Steel coil overs. Made a huge difference on how the car drives and feels on the road. Pricey, but worth it to me. Mine was stock before, and when I did my restoration on it, put it back to stock. It was okay, but still rode like an old car to me. Like others have said, if you keep it stock, go with rubber bushings. If you upgrade, check out the various vendors stuff.
Old Oct 27, 2021 | 04:14 PM
SteveJB's Avatar
SteveJB
So castor changes wont matter? Why do some suppliers claim its good?
Old Oct 27, 2021 | 04:45 PM
Jarhead 74 Vette's Avatar
Jarhead 74 Vette
Veteran: Marine Corps
On my 74 I’m sticking with stock upper and lower control arms, but going with DelALum bushings from Global West that will undoubtedly outlast and outperform repop rubber or poly bushings, hands down. I bought offset upper control arm shafts as well.
Since mine will be strictly a street driven car ( but with some very spirited driving on our mountain roads) I’m going with adjustable coil over shocks along with an oversized sway bar.
Bilsteins are also a great set of shocks.
On a side note:
If you’re considering DelALum’s, be advised it will require a little fabrication work on your OEM components.
IF you go this route, do your homework on who you have do your fab work. Trust me, not every “Joe Schmuckatelli” speed shop knows how to follow simple directions.
I would highly recommend shipping your necessary parts directly to Global West to save yourself some headaches, or do like I did my second time around, took my components to Dub in Charlotte. He’s FANTASTIC!
Google Global West DelALum install for more info and a detailed video.
I look forward to getting my resto mod project back on the road ASAP.
Best of luck with your choices!!
Old Oct 27, 2021 | 04:56 PM
interpon's Avatar
interpon
you asked about installation..see below.. also used non china parts..rubber..rear sway bar and struts i used energy suspension USA poly all good..
i would upgrade springs.. stiffer ...i went #474 moog USA and not harsh at all.. buy bilstein shocks..you will be impressed when done
pay attention post #22
https://www.corvetteforum.com/forums...rs-method.html
Old Oct 27, 2021 | 05:16 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
More positive Caster does matter. They give you a better feeling in the steering wheel of what the tires are doing, and the car tracks truer on the highway in a straight line. It may feel less twitchy at all times. It was only built this low on C2/C3s because many of the early C2s had manual steering. PS was not std til about 77.
As long as you have PS, why put up with antiquated caster?
You can get from 2-3 degrees caster with stock a-arms, another degree or so with the offset shafts, and another 1.7 degrees if you elongate the hole in the shaft 1/4". For a total of about 5. Or you can buy new arms that are built with more caster.
Old Nov 5, 2021 | 10:17 AM
SteveJB's Avatar
SteveJB
Thanks for all the great advice. Is there a spreader bar that will not have clearance problems? I am using a 350 small block and the spreader bar pics is see look pretty tight.
My plan for the front end is:
GW offset cross bars, springs and shocks, Ridetech derlin bushings (let me know about this if you have experience please), larger sway bar and spreader. This will be stock otherwise, about 400 HP is the plan (using Vortec heads, mild cam). Ill get to the rear after i finish the front this fall.
Old Feb 12, 2025 | 02:48 PM
SteveJB's Avatar
SteveJB
This is a post meant for another thread. Sorry.
Old Feb 16, 2025 | 02:53 PM
vettebuyer6369's Avatar
vettebuyer6369
Post to old thread in error.
To 76 Front Suspension Rebuild
