1972 C3 Fuel Pump Woes
Pump
In-line filter
adhesive for the pump seal
I need to go back and purchase some rubber fuel line and hose clamps. A couple questions. Am I missing anything or is there anything else I should consider? Also, what is this third fuel line that goes to the bottom of the pump and seems to run parallel to the main fuel line back to the gas tank?
The Carb is newly replaced this last fall before I purchased the car. The car hasn’t been driven much over the last 8 years, but I’m planning to make it my daily driver after I get it up to snuff. My father-in-law is a whiz with engines and he is a great resource over the phone. Unfortunately he’s 6 hours drive away or he would have had this apart and back together in a fraction of the time it is taking me.
Thank you in advance for any helpful hints or advice.
The fuel pump
The extra fuel line that seems to run back to the fuel tank. The main fuel line is underneath it. Please correct me if I’m wrong. I just don’t know the function of this extra line. It didn’t appear to be the fuel supply because I didn’t have to plug it like the main fuel line.
This is where the extra fuel line was attached on the bottom of the pump.
So, your replacement pump must have not only three ports, but the ports should face in the correct orientation. I would recommend another Delco for stock or moderate H.P. application. If that original Delco made it 50 yrs, a new Delco should . . . . . .
You will also need a fuel pump gasket, a fuel pump mounting plate gasket + Permatex Black. Go ahead and change the plate gasket while you're in there. Apply goop on both sides of both gaskets also.
By placing the engine in the #1 TDC the pump pushrod will be the farthest away from the pump arm. This makes it a lot easier to install. The rod will try to drop down but there are ways of holding it into position, but I have had success by just being faster than the pushrod. Once you get one bolt started you have it made.
Bob K.
You mentioned replacing the inline fuel filter. What type of inline filter does your car have?
What carburetor are you using?
What engine do you have?
Your engine should have a Quadrajet unless it is an LT-1 which used a Holley. Both left the factory with a metal fuel line.
When replacing the fuel line, be sure to use hose specifically designed for fuel. The feed line that goes from the frame to the fuel pump, is a preformed hose specifically for your car. Many have tried to replace it with ordinary fuel line and soon discover that it will kink and restrict fuel flow or fail prematurely. Be sure to purchase the correct hose to avoid this problem. This is what the frame to pump hose (Molded "S" Hose Kit) should look like...
https://www.paragoncorvette.com/p-35...-hose-kit.aspx
The return hose is more straightforward, but is 1/4" fuel line and looks like this...
Good luck... GUSTO
they're pre-formed for a reason.
https://willcoxcorvette.com/corvette...it-front-70-82
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
These kits are available at the GM Heritage Center website for most GM vehicles.
Good luck... GUSTO
Not available in any store. Don't be fooled by other knock-offs.
But wait! Call in the next 10 minutes and receive two offers for double the money. Plus we will throw in four clamps. Absolutely free. (plus shpng / handling fees)
And in addition, receive a pair of micro-fiber towels to first five customers. Act Now!
When changing the fuel pump on my 69 350 with A/C I found I had to remove the lower radiator hose to get at the fuel pump bolts. Also, removing front tire helped.
I used Tampa Jerry's method for holding the fuel pump rod up. It works!
VS
Good luck... GUSTO
Jebby
The original fuel filter was in the housing screwed into the Q-jet carb body.
Jebby
Anyhow, it’s back in place and the radiator is full again. The car started right up, and it runs WAY BETTER now. Before (with the old fuel pump), the car would cough and sputter and would choke-out if you even touched the gas peddle right after startup when cold. Now? It starts cold and purrs like a kitten from the start.
I’m very happy with the results. Now on to the next project. Thanks guys for all the helpful information.
A picture will do. If you tell us the carb, we can likely link you to the correct metal line for your engine.
Good to hear you've solved the fuel feed problem.
GUSTO
