1980 headlight actuator problem
Old Feb 21, 2020 | 06:46 PM
BlackC3vette's Avatar
BlackC3vette
Default 1980 headlight actuator problem
The dust boot on the passenger side actuator was missing so I pulled it out to replace it (new shaft boot seal also) . Before putting it back in I decided to put the minivac on it and it would not hold pressure. Ok, new actuator ordered from trusted vendor and just for the heck of it I put the minivac on it and it would not hold pressure either. I rechecked the vac, it holds pressure just fine, the connections were all taped just in case, no good, the actuator moves just fine but will not hold pressure. The vendor is exchanging it, but are these Chinese made, will I ever get one to hold pressure?
Old Feb 22, 2020 | 01:36 PM
SwampeastMike's Avatar
SwampeastMike
Yes, they are Chinese made. You'll probably get one that holds vacuum eventually but how long it lasts is anyone's guess. This problem has been going on for years and I'm surprised it has not been addressed.
Old Feb 22, 2020 | 02:48 PM
BlackC3vette
Thanks for the reply, I was starting to think I was the only forum member to ever receive a defective new actuator. The vendor on the box label is called Auto Accessories of America (AAAdirect.com), which is not the vendor I got it from but I would think AAA is the one who imported it. I tried calling them Friday, but it was too late in the afternoon and they were closed. Anyway, I did ask the vendor I got it from if the actuators were pretested before being shipped and he didn't know.
Time to start looking at electric, without the nightmare of pulling out the headlight switch on this 80 and a $900 price tag?
Old Feb 22, 2020 | 03:28 PM
SwampeastMike
It's a problem with ALL vacuum products. Check them FIRST before installing! Slightly leaking switches that can easily be disassembled (like on the headlamp switch, the HVAC selector, override switches, warm-water shutdown switch, etc.) are often indefinitely (read years if not decades) repaired using nothing but some silicon grease (aka "plumbers' heat-proof grease").
Before you give up on vacuum do a little searching for a forum member who repairs original actuators.
Old Feb 24, 2020 | 12:37 PM
L-46man's Avatar
L-46man
Default plump it up!
Dear Black C-3....I am messing around with one of the lights on the 69. 51 year old headlight actuators. I always do a leak-down test.
According to the AIM -20" of vacuum is what they recommend. 20" up and 20" down. I listened to the opposite tube to immediately tell if there was an o-ring problem...there was none.
The 51 year old actuators held vacuum for 8 hours! The leak-down was 10" over 8 hours. Or said another way...after 8 hours they still had 10" in them.
(The problem with mine is the adjustment of 'landing'....one corner is too low...)
One way to 'swell' rubber o-rings is to soak them in liquid silicone....this causes the rubber to 'plump-up' and be more compliant.
Temperature is also a factor.... I have to assume you weren't messing around in the driveway at 0° F!
Unkahal
To 1980 headlight actuator problem
