Blast it, dip it or heat it???
If you dont have a lot of rust inside just sandblast and paint/coat the outside call it a day.
Spray oil or? on the inside if it bugs you.
I powder coated everything that could possibly be coated with a cheap Eastwood gun and an old household oven. I even powder coated the heads of the bolts and nuts. You are absolutely right. Once it is powder coated there is no tweaking anything, but the powder coating holds up extremely well. I had a gas leak that had no effect on the coating and I used SS brake lines which I had to work like crazy to get to seal. Ie Brake fluid on many components. No damage. Cleanup is a breeze You just blow the gun out. And it is much cheaper than good quality paint.
I reworked smaller pieces after they were powder coated by blasting the coating off. The coating is extremely hard to remove even with sand blasting. I also found that you cannot use any abrasives on the coating (I.e. rubbing compound) it scratches and I couldn't get the scratches out.
I stayed away from heating the frame excessively. (800F+) No good can come from putting that much heat on the frame. I suspect the residual stress and heat will at least somewhat distort the frame. Galvanizing is a really great option if you want the frame to last forever. I personally believe it depends on how you are going to use the car as to what technique you should use.
My '72 frame is original and obviously has rust, but nothing to the point of significant repairs. I would like the frame to outlast me, which god willing will double the age of the car. I live in Cleveland and the closest, reasonable dip location I have found is in Nanty Glo, Pennsylvania. Before I rent a truck and/or trailer combo and drive 6 hours round-trip twice with crappy gas mileage and ample tolls, does anyone have a place they would recommend, considering the geography?
